benched and balanced ip
Postby fatstack » Mon Apr 30, 2012 7:33 pm
Are there any reputable shops i can send my ip to have it benched and balanced to max cc's correctly without paying an arm and a leg while i have it off?
89 d250 getrag ripper, pump maxed,timed to the head,pull cable shutoff, 354 spring, straight pipe, 4:10 gears, in the shop: he351cw and 3:07 gears
90 w350 nv4500,ic motor, stock, 5" stack w a western hauler on back
fatstack
Re: benched and balanced ip
Postby dazedandconfused » Tue May 01, 2012 4:53 am
I believe Buddha power does it.
Postby tampabayBill » Tue May 01, 2012 7:38 am
Buddha Power contact info ?? I've seen him referenced alot on here but trying a goggle search all I get is a bunch of mystic BS
Twins coming soon!
tampabayBill
Postby Tacoclaw » Tue May 01, 2012 8:25 am
viewtopic.php?f=4&t=1290
Found that gem clear back on page 34 of 37 in The Good Stuff. Look at how innocent and curious Begle was back then. :)
From what I read over on CompD, John Russin was in an accident of some sort recently, I doubt he's taking on much work right now. Couldn't hurt to call and ask though, I guess.
Postby fatstack » Tue May 01, 2012 8:05 pm
Seems to be john russin is deseast );. Does kta bench pumps?
fatstack
Postby dazedandconfused » Wed May 02, 2012 2:12 am
fatstack wrote:Seems to be john russin is deseast );. Does kta bench pumps?
Huh? According to compd he was doing good.
http://www.competitiondiesel.com/forums ... 154&page=2
Postby CUMMINSDODGEMAN3 » Wed May 02, 2012 5:32 am
Where are you located?
Team Green's old hauler 05 3500 CTD 4x4 6sp 8in rize industries lift, 37 Toyo M/T's, Smarty, Edge Att, AFE intake, ATS manifold Borg Warner turbo, 5in SS MBRP
90 W350 CTD SRW big pump, big turbo, lots of fuel, 47RH billet suncoast triple disc and 20's
93 D250 CTD ext cab pump work, POD's
CUMMINSDODGEMAN3
Postby fatstack » Wed May 02, 2012 9:36 am
Im sorry john link i believe. im located in oklahoma
fatstack
Postby CUMMINSDODGEMAN3 » Wed May 02, 2012 10:02 am
Shiver Diesel is where you need to send your pump to for sure...
http://maps.google.com/maps/place?hl=en ... 3932180278
CUMMINSDODGEMAN3
Postby CUMMINSDODGEMAN3 » Wed May 02, 2012 10:09 am
call and ask to speak to Robert and tell him Free said to call.
CUMMINSDODGEMAN3
Postby Kasper Cummins » Wed May 02, 2012 6:22 pm
What's the point of having a pump bench tested other then seeing how many cc's it flows?
I know it might be a stupid question but, I have never found anyone say why they do it.
92 W250 club cab
Kasper Cummins
Postby welderboy250 » Thu May 03, 2012 4:35 am
Any inline pump has to be benched so that all the barrels are balanced in terms of start of injection as well as delivered quantity.
However, with a rotary pump such as ours I see no reason other than to make sure it delivers as much fuel as u desire. Taking it apart and reassembling it does not throw it off balance the way it does with an inline.
1990 W350 5spd. IC'd front end, HX52 on ported 3 piece, full 4" pipe, not as much power as I want but more than enough to break something
Jimmy
welderboy250
