Hx55w .......need specs please
Postby singlesmoker06 » Fri May 11, 2012 6:23 am
I have an hx55w and can't find the specs on it anywhere on the net, tried google, didn't work anyone know the specs off hand??
4037620
050406402
4037626
Hx55w
Thanks
91.5 d250 auto. $800 truck just for fun, 3200 spring, big injectors, big turbo, now have money out of pocket ....
SMOKED OUT DIESEL PERFORMANCE
817-578-5308
singlesmoker06
Re: Hx55w .......need specs please
Postby oldestof11 » Fri May 11, 2012 2:00 pm
It is about 64/78. Laggy as a single.
Postby singlesmoker06 » Fri May 11, 2012 3:37 pm
Thanksfor the reply, planned on using it on a small twins setup idk, it's laying there collecting dust so might as well do something with it , I know there's lots of variations if this turbo, including small and larger shafts, I wonder If this had the larger or if it would be worth playing around with, it's a fun driver just to play with so all advise would be appreciated
Thanks again
817-578-5308
singlesmoker06
Postby Kasper Cummins » Fri May 11, 2012 4:04 pm
How hard would it be to put it on? If it's a T3 flange and you just need to change the down pipe, it might be worth trying.
92 W250 club cab
Kasper Cummins
Postby oldestof11 » Fri May 11, 2012 4:25 pm
It is about the same size as "towing" twins.
And I bet it is T6 flanged also.
Postby singlesmoker06 » Fri May 11, 2012 4:32 pm
It's got holes drilled it the flange for a t3 I believe just never tried to mount it, if I remember correctly a while back, several years I believe, I was told they were real weak and notorious for snapping shafts as a single, but as a twin setup, they would be ok, the way I figure it, is even if I did it and it didn't work well or last long, I'd at least have the setup built to run another set with minor mods, I just don't think it would be fun as a single until it lit .... But when it does........
817-578-5308
singlesmoker06
Postby welderboy250 » Fri May 11, 2012 6:27 pm
Everyone I've ever seen has the same size shaft, even 50's just that the od of the bearing is bigger on 55's
1990 W350 5spd. IC'd front end, HX52 on ported 3 piece, full 4" pipe, not as much power as I want but more than enough to break something
Jimmy
welderboy250
Postby welderboy250 » Fri May 11, 2012 6:30 pm
By the way, I would like to debate the possibility of the compressor wheel being 64mm. I've never actually seen a 50, 52, or 55 with an even number size compressor wheel. Always a 65, 67, ect.
Jimmy
welderboy250
Postby oldestof11 » Fri May 11, 2012 7:00 pm
It is like 63.7 or 63.8. Close enough to 64 for me.
Postby welderboy250 » Sat May 12, 2012 12:56 am
10-4
Jimmy
welderboy250
