Buddha Power contact information?
Postby Begle1 » Wed Oct 03, 2007 12:22 pm
Does Buddha Power have a phone number or website? I haven't been able to find anything.
Postby KTA » Wed Oct 03, 2007 12:40 pm
1-440-968-3813 Its a one man show so you will probably have to leave a message.
Postby Begle1 » Wed Oct 03, 2007 1:29 pm
Excellent.
Thank you good sir.
Postby DTanklage » Sun Oct 07, 2007 12:21 am
what size injectors did you end up goin with?
DTanklage
Postby Begle1 » Sun Oct 07, 2007 7:10 am
DTanklage wrote:what size injectors did you end up goin with?
None yet. I have cold feet for that kind of money.
If I wanted to be smart I'd pull my stock ones out first and see if scrubbing and getting them pop tested does any good. If I get injectors, I'll be stuck at 300 HP for another year anyways due to a lack of air.
I'm looking for as large injectors as I can get that I can pansy pedal without smoke.
Postby DTanklage » Sun Oct 07, 2007 12:38 pm
you can put injectors large enough to blow up your turbo in there, and if you drive it easy it wont smoke at all...
if you want 300 hp pods are plenty big
AND THEY ARE CHEAP
DTanklage
Postby DTanklage » Sun Oct 07, 2007 12:40 pm
ps - i would even be willing to sell you the set that are in my truck now
what is the most you would give for a used set?
don
DTanklage
Postby Begle1 » Tue Oct 09, 2007 10:16 am
Most guys running POD's and a fair number of the 435's and DDP 4's get the hazey idle, which is what I need to avoid.
From what I gather, the custom sets can go just as big as the POD's, or even bigger, with less-to-no haze.
What injectors do you have? I would rather not buy some now that I won't have the ability to use for another year.
How much do the copper washers for the injectors cost?
Postby DTanklage » Tue Oct 09, 2007 12:57 pm
i have bd 4x14's in my truck (pods)
total cross sectional area of ea injector is .000615"
they dont haze at all at idle and the truck gets 20 mpg if i drive it easy
if you are not looking for injectors for another year why are you asking all the questions now?
DTanklage
Postby Begle1 » Tue Oct 09, 2007 3:17 pm
I could get injectors... Don't know what the best option would be at the moment, though.
Postby DTanklage » Tue Oct 09, 2007 5:21 pm
a used set of pod's
you would have to tune the afc so that they would not blow up your turbo
you can not remove the lever and run them with that turbo
DTanklage
Postby Begle1 » Tue Oct 09, 2007 8:23 pm
I'd consider a used set of POD's if they were $200 or so.
I think I'm buying a head instead of a set of custom injectors. That way I can have my turbos set up before I get the custom injectors. But that means I need to buy injectors twice. Actually, some used POD's become worthwhile in that situation.
But I need to wait to get my fueling gremlins fixed before I spend a dime, or else I'm going to be making credit card payments on an IP...
Postby wannadiesel » Wed Oct 10, 2007 4:09 pm
DTanklage wrote:a used set of pod's
I guess I didn't do it for a year.
Not that I'm recommending it, it was hard to drive clean and EGT's were downright nasty at full power.
Best dyno: 408/844
wannadiesel
diesel guru
Postby DTanklage » Wed Oct 10, 2007 7:06 pm
i do not understand your post
i got the part about you requiring a afc lever, but that was it...
what turbo were you running when you removed the lever?
DTanklage
Postby wannadiesel » Thu Oct 11, 2007 2:41 pm
I ran POD's, a ground AFC lever, and a WH1C for about a year.
Best dyno: 408/844
wannadiesel
diesel guru
