can someone please explain what happend?
Postby gomerpile » Thu Oct 04, 2007 6:07 pm
alright i just got doing a little modding to the pump, (2 turns on screw) and for some reason i went from having 17 lbs of boost at 1100 F (1/2 turns of screw )before tinkering, to barely 15lbs of boost at 1050 F (maybe) (2 turns of screw) afterwards. and yes i turned the screw clockwise and thats all i did. can someone explain this?
1992 Dodge D-250 LE auto, LSD w/3.54, about 200,000+ miles.Isspro Pyrometer , Sunpro tach,Tractor Supply Boost Gauge, Old Smokey Fuel Pin,4 turns on fun srew, starwheel turn CCW 1 turn, 40hp injectors, BHAF,16 cm housing.Sony Head Unit.
gomerpile
Postby KTA » Thu Oct 04, 2007 6:25 pm
Check the air line from the head to the afc, you might have broke it or left it loose while messing with the fuel screw.
Postby gomerpile » Thu Oct 04, 2007 6:53 pm
well i didnt loosen the afc line. u dont think bumping it could do anything?
gomerpile
Postby GLHS » Thu Oct 04, 2007 10:41 pm
If you broke or cracked the line, yes.
GLHS
