PToombs wrote:I control mine with a set of 5" stacks!
Actually, it's only real bad when I get on it hard down low.
ford69557ci wrote:i broke my afc lever off and started havin fun again
DTanklage wrote:and this was with the afc lever intact?
did you try backing out the smoke screw?
if so do you want to trade pumps?
sounds like yours is pushing more fuel than kta's...
DTanklage wrote:mike, if the pin is starting off too low BACK OUT THE SMOKE SCREW
i doubt the spring is the culprit if you are driving with light throttle and are not getting into boost
don
