big turbo
big turbo
Postby ford69557ci » Sun Oct 14, 2007 8:53 pm
i was looking at a twin turbo set on ebay ad it has a big brother turbo. i also have noticed that ii and piers both offer a big brother turbo in thier race twin setups. so what are the secs on this tubo and what compares to it and hx60 k31 or somethin else?
ford69557ci
is this a big turbo on the left? (htt 62-13 on right)
Postby DTanklage » Sun Oct 14, 2007 10:05 pm
DTanklage
Postby DTanklage » Sun Oct 14, 2007 10:06 pm
DTanklage
Postby DTanklage » Sun Oct 14, 2007 10:07 pm
DTanklage
Postby ford69557ci » Sun Oct 14, 2007 10:29 pm
so these r what???an s 300-400 and a ????????????
ford69557ci
Postby Begle1 » Mon Oct 15, 2007 6:59 am
I'm thinking that the big one is a Big Brother?
Under which case the little one is an S400? I'm pretty sure that the Big Brother is larger than the S400/ B2.
Postby ford69557ci » Mon Oct 15, 2007 9:46 am
so if i was to go to my local heavy engine core place what would be compareable to a big brother and what would it be off of?
ford69557ci
Postby DTanklage » Mon Oct 15, 2007 11:06 am
it says on the first pic that the small one is my 62/65-13
(schweitzer s300)
the big one is a garrett
75mm wheel in a .75 a/r compressor housing and 86mm turbine in .96 a/r ex housing
got it as collateral for an ignition system i build for a guys drag bike
he never finished paying me - still owes over $800
think i can get that much for this turbo?
it is brand new
don
DTanklage
Postby ford69557ci » Mon Oct 15, 2007 11:11 am
the small turob is identical to my c7 cat turbo that i currently run as a single if i could figure out how that big one compares to a big brother thyen i might be interested
ford69557ci
Postby DTanklage » Mon Oct 15, 2007 11:31 am
it takes a 5" dia air filter and typical 5" dia ex flange
i posted the sizes of both wheels and the a/r ratio of both housings
what other info do you need?
DTanklage
Postby DTanklage » Mon Oct 15, 2007 11:35 am
pps - i am pretty sure that this is too big for towing twins but if you are going for huge power for pulling or drag racing i bet you could make it work
prolly take a lot of fuel and a lot of rpm to lite that thing tho...
DTanklage
Postby ford69557ci » Mon Oct 15, 2007 12:26 pm
i dont tow anything anymore im havin a twin disc built right now so i think the only thing i will be pullin is a sled and away from the vettes and imports lol
ford69557ci
Postby DTanklage » Mon Oct 15, 2007 4:08 pm
DTanklage
Postby ford69557ci » Mon Oct 15, 2007 5:33 pm
i actually think i found a great bottom turbo for a large race/pull twin setup its a k44
ford69557ci
