installing stacks
installing stacks
Postby k5cowboy » Wed Oct 17, 2007 9:56 pm
hey, i just ordered some 6" stacks. i have a 93 club cab, and i want the stacks to be right up to the front of the bed, but i have a bunch of frame and box re enforcements rigth where i want to cut my hole(under the bed). what do you guys do?
k5cowboy
Postby slicknickz » Wed Oct 17, 2007 10:25 pm
Under my single cab truck there is a brace that supports the bed right where my 90 came up I just cut a half circle on it and ran the pipe. I don't know about frame pieces tho. hope it helps. If need be I can possibly lay under the truck and take a pic of how mine is if i find time.
slicknickz
Postby RumbleFish » Thu Oct 18, 2007 12:34 pm
Personally, I hate stacks. But if I were to do them, I would use some elbows to go around the crossmembers/reenforcements, thru the bed, another 90* toward the front bed wall, into cross over box/Y/whatever you have. If you have a tool box it will hid this nicely. Somebody had pics of this setup, but I duon't remember who.
Postby PToombs » Thu Oct 18, 2007 6:05 pm
Anti-stacker! :shock:
Run a 90 to the outside of frame, 1 up into the box, missing all members. Then you can use square tube, pipe or whatever to hook up inside. I have a diverter valve on my D250, and the 90 comes right off the valve under the frame, then up into my 4" square tube. I do have a flatbed though. My buddy did his 3rd gen with 2 90's like this, then set his square tube up on legs so he can haul plywood and 'rock.
Postby ford69557ci » Thu Oct 18, 2007 6:14 pm
stacks look cool but i like my big fat 8 inch tip aimin right at the tail gatin dummy or the jackass yappin on thier cell phone beside me lol
ford69557ci
Postby PToombs » Thu Oct 18, 2007 6:19 pm
That's why I have the valve, 2 positions, up or smoke 'em! :lol:
Actually, it's for hauling the camper or gooseneck, so stuff stays cleaner. Quiet on long trips too, muffler in tailpipe circuit. :wink:
Postby ford69557ci » Fri Oct 19, 2007 1:05 am
i just have strait 6" and it isnt loud at all in the cab till i open the bac window but when the turbo hits the smoke flys and traffic stops 8)
ford69557ci
Postby CumminsPride » Sat Oct 20, 2007 6:42 am
We built a set with a piece of 4"x8" square tubing and just welded the 4" collar right above the exhaust (under the bed). Then flex it right up into the 4" welded collar. Since we used 8" wide tubing we were able to set the inlet back and the stacks forward. P.S. don't forget to do a leak test before you cut the stack openings. We just filled it with water from the inlet side.
Wade
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby PToombs » Sat Oct 20, 2007 3:30 pm
Wade, that's a good idea! 4x8 is kinda expensive isn't it?
Postby CumminsPride » Sat Oct 20, 2007 4:41 pm
Thanks. Not at C Henry Steel in Fort Wayne. It's second hand steel and it's .30 a pound now. Also any scrap metal buyer depots will let you come in and torch out what you want for around .25 per pound.
Wade
CumminsPride
Postby k5cowboy » Sat Oct 20, 2007 6:01 pm
so you used the 4x8 to move the exhaust back to the end of the cab? wouldnt that really mess up your flow? i was thinkin maybe 2 pieses of flex exhaust. have Y come up past the member, then run the flex on each Y exit, to the stacks..
k5cowboy
Postby CumminsPride » Sat Oct 20, 2007 6:28 pm
Here's a picture.
CumminsPride
Postby CumminsPride » Sat Oct 20, 2007 6:42 pm
I've tried everything. I can not handle these computers but I CAN WELD! Copy and paste the darn url there in your address bar and click on my albumn. That is as good of a picture I could get you without driving to the truck that has the stacks.
Wade
CumminsPride
Postby RumbleFish » Sat Oct 20, 2007 8:20 pm
Postby TWorline » Sun Oct 21, 2007 9:31 am
Hey Cumminspride how close to Ft. Wayne are you? I am a hour East over in Ohio.
Tim Worline
http://www.CoolerTubz.com/
TWorline
