RCCUMMINS89 wrote:Ok.... then this should be an easy thing to do.
What I plan on doing is making a block off plate that doubles as a timing spacer that is twice as thick as the M&H one. Then have an adjustment that has the has the ability to be turned in to where a stock truck and timing set up would be and then backed off up to a double the "normal" spacer distance.
Suggestions on that? Also on these regulators, if one were to just swap in a diff. would it throw off the case pressure from what it was stock (are these adjusted when the builder builds the pump)
Going double that of the M&H may not be feasible. Might consider ADDING a similar spacer to the opposite side of the case (now, one on each side).
I think the regulators are adjusted as the pumps are initially set up.
I got's to go to bed. We'll talk more.
