by RCCUMMINS89 » Tue Apr 02, 2013 3:24 pm
Well.... here is the thing. You'll be hard pressed to break 400hp at under 45 psi. I assume you want that to avoid studs? Regardless of the set up 400 won't be had on stock head bolts, this I know.
Under a grand for injectors can def. be had and I can get you premium all Bosch stuff that has all the goodies done to it for quite a bit under that.
If you do plan on running a 14.... you'll need a huge injector in order to keep it alive, including an expensive lift pump. Were you still planning on trying the 14?
89 RC on shortened 92 diesel frame - NV4500 w/dual disc/4.10s on 37s. - Self built pump, "hot screw", lots of timing, True high volume low pressure lift pump, 62fmw/68/.7gated, 77lpm SAC Inj., Studs/O-rings,- 423/1220 Mustang - 11/16/2013
http://www.TheHungryDiesel.com full line dealer, if you don't see it please ask.
