injection pump woes
injection pump woes
Postby TX1GEN » Wed Mar 06, 2013 12:42 pm
yet again, ive sprung a leak!
now i figure ill just buy a new one instead of going through the hassles and all that.
now the question is which one. do i go back to stock? do i run BD DIESELs +230hp pump pn-bd1051205 orr industial injections pn- 0460426205SHOSE]
'93 dually single cab 2wd 4" TBE, POD injectors 4x14, airdog II 165, 365hp/925ft lbs
TX1GEN
Re: injection pump woes
Postby Bob L » Wed Mar 06, 2013 2:41 pm
" do i run BD DIESELs +230hp pump pn-bd1051205 orr industial injections pn- 0460426205SHOSE]"
Which one is best ?. One is a little more expensive than the other.
Bob L
NRA Life Member 1974
'92.5 D250 LE EXT.CAB...Getrag...All Original...No Rust...
Purchased new in late Oct.'92---128K Mi. Still Like New.
Bob L
Postby tampabayBill » Thu Mar 07, 2013 8:53 am
I run the BD pump but look around there are pumps out there that come with a 3200 rpm spring and an aftermarket fuel pin already installed which the BD pump does not. As always price makes a difference.
Twins coming soon!
tampabayBill
Postby TX1GEN » Thu Mar 07, 2013 2:29 pm
im not sure on which one is best... i know the bd ran around 1250 industrial was like 850 and also after talkin with rccummins89, he let me in on scheids they have a 12mm adn 14mm pump. i would like to run that 14mm but its high dollar comin in at like 2350.
as far as whos is best, and whos to buy, i just dont know.
TX1GEN
Postby RCCUMMINS89 » Thu Mar 07, 2013 3:14 pm
It's no different than asking which injection pump shops are best..... It's hard to say and both good and bad come out of places.
Postby OleRed5.9 » Mon Mar 11, 2013 1:25 pm
I got the schieds, and they seem to take more attention to detail on things. Plus customer support is outstanding.
OleRed5.9
Postby RCCUMMINS89 » Mon Mar 11, 2013 1:33 pm
If one were to spend money on a "big name pump" no doubt Scheid's is the best. But it is also the most expensive.
Postby OleRed5.9 » Mon Mar 11, 2013 1:48 pm
I go by experience. Not price. I've tried others and paid less... All depends on who is building it and who backs there build. Schieds has not let me down yet
OleRed5.9
