So, I wanted to give "the best quality" non bosch nozzle a try.... I was hoping that these would be able to be an affordable answer to the expensive Bosch nozzle prices.
Here is the results..... Even though companies may offer a "matched set" doesn't mean a thing. I was going to have a set flow honed in order to find the metal consistency. This couldn't be done very well because all 6 nozzles were a slightly different lengths. Ever wonder why some get a lot of smoke and hazing problems with aftermarket injectors? It is like putting in different thickness washers on every nozzle.
To top it, 1 nozzle opened up almost 15 lpm on the first flow and it took about 6 flows on one just to open it up 10 lpm.... obviously problematic.
So in short, I won't be carrying non bosch nozzles. Sad, but true. I won't be able to offer cheap injectors to compete with the other affordable injectors out there.
