ve 24v
Re: ve 24v
Postby Tacoclaw » Sun May 26, 2013 7:14 pm
Looks good, man, with all the shenanigans you're pulling a I can't imagine 500 horse will be that tough to get. Think it may be an air thing?
Re: ve 24v
Postby dazedandconfused » Sun May 26, 2013 7:16 pm
What do your injectors work out to be now?
Re: ve 24v
Postby Stomp » Sun May 26, 2013 9:00 pm
turboram wrote:There is also about a half dozen guys around the country shooting for that 500hp mark on a 12mm right now.
Well I guess ill have to put a 12mm on and push for 500 rwhp :mrgreen:[/quote]
Im all ready one step ahead of you. I have my hot little 12mm pump on right now. I also swapped out my top turbo for a smaller one to get it to light a couple hundred RPMs sooner.
Stomp
93W250CTD,7 isspro gauges,Piers stage 2+ ported/polished/o-ringed head,ARP 12mm studs,ATS 3 piece,Custom twins by Brad @ Ponci's Diesel Center BTH3B/26 w/Piers HX40/16, custom 4"exhaust/ intake by Brad@ PDC,370's,KTA-Special 14mm Head/Rotor
Stomp
Re: ve 24v
Postby turboram » Mon May 27, 2013 5:50 am
My 83 mm turbo that is on the shelf says there wont be an air problem. ;) I just wont run it long because I pull in a turbo limited class like 63.5 mm inducer . My calculations tell me a 12mm pump will only net 525 rwhp tops
turboram
Re: ve 24v
Postby RCCUMMINS89 » Mon May 27, 2013 7:56 am
turboram wrote: My calculations tell me a 12mm pump will only net 525 rwhp tops
Weird...... my "calculations" (voices in m y head :lol: ) said that if I maintain the same efficiency as my last run, I would be at 525rwhp (same efficiency :roll: , ya like I'll actually be able to maintain that)
my goal is 523rwhp in Sept.
Re: ve 24v
Postby turboram » Tue Jun 11, 2013 6:18 pm
This is one of the pistons out of my motor that made 600hp Image
turboram
Re: ve 24v
Postby dazedandconfused » Tue Jun 11, 2013 6:45 pm
Link doesn't work.
Re: ve 24v
Postby Deathrod » Tue Jun 11, 2013 9:57 pm
^^^^^looks like it got a wee bit toasty
Deathrod
Re: ve 24v
Postby dazedandconfused » Wed Jun 12, 2013 4:08 pm
Yeah I would say she was hurting. Is the new motor ready to go in yet?
Re: ve 24v
Postby ahale2772 » Tue Jul 09, 2013 4:25 pm
this sure makes me want to play VE again, my 94 has been so stupid easy to get fuel out of it takes the fun out of it.
congrats turbo ram!!
care to share any info on what you saw with case pressure VS timing with your pump? saw you mentioned you were looking at that on your bench earlier in the thread.
Re: ve 24v
Postby turboram » Wed Jul 17, 2013 9:25 pm
A 4mm camplate is on order...... testing will commence next month :D If it holds up I predict 800+ fuel only :twisted: :twisted:
turboram
Re: ve 24v
Postby oldestof11 » Thu Jul 18, 2013 5:33 pm
Speechless...
