Exhaust Manifolds
Exhaust Manifolds
Postby grinnergetter » Sun Apr 07, 2013 7:07 pm
Uhm, so I'm digging around for info and I can't seem to find a search function for the boards. I'm sure I just having one of those blind moments and it's right there. :oops:
Anyway, I would like to upgrade my exhaust manifold and am trying to find some experience with the aftermarket one's.
Thanks for any suggestions.
grinnergetter
Re: Exhaust Manifolds
Postby 4thesporty » Sun Apr 07, 2013 7:21 pm
Why?
1994 Chevy K3500 12V/NV4500
Full rebuild with mahle non I/C pistons, 370s (set @ 250 bar), HX35/HT3B, custom cam, studs and orings. Yep, it's a VE :)
Still in progress
4thesporty
Postby skilletky » Sun Apr 07, 2013 7:25 pm
ive heard that ats flows the best. its the one ats product that i have that i actually like. anything would be better than a shrunk up stock manifold. or just buy a new oem manifold and gasket match port it. save ya some money that way.
skilletky
Postby grinnergetter » Sun Apr 07, 2013 7:51 pm
Found a crack today in my donor's manifold....do I need so many posts to have access a search function?
grinnergetter
Postby RCCUMMINS89 » Sun Apr 07, 2013 9:15 pm
No.... but our search function sucks anyways.
Most aftermarket manifolds flow about the same (little better) than our stock manifolds. Now saying that, if you have a crack, might as well go with a new 3 piece....
Postby turboram » Mon Apr 08, 2013 4:26 am
Ats does not flow the best......but I would order a 3 piece if I were you whether it be ats or someone elses
turboram
Postby BC847 » Mon Apr 08, 2013 5:22 am
The search function buttons are found at the top/right of the page (in the blue). Use of the Advanced Search is recommended.
Postby grinnergetter » Mon Apr 08, 2013 8:20 pm
Thanks everyone...yea that search function could use some improvement, guess I'll run across all kinds of cool threads diggin around here.
grinnergetter
Postby bmoeller » Tue Apr 09, 2013 11:47 pm
Ran an ATS on my 97 and 99 trucks. Was a slight gain in spool up, 50* drop in EGTs and about a 5psi drop in peak boost. Whether ATS flow the best or not, there was still a modest improvement over stock. Stocker on the 97 had shrunk (only 2 straight bolts on it) and the one on the 99 was a good used one that was ceramic coated. Plan to put one on the crewcab motor for sure.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby dazedandconfused » Wed Apr 10, 2013 4:04 am
I use the Google custom search feature.
Postby Tacoclaw » Wed Apr 10, 2013 4:12 am
There's also a search bar right on top of the list of the threads in each subforum, it's nice if you just know where something should be located. Like searching fusible links, you know they're going to be in the electrical section so just use the little search bar there.
If you want to look like a baller and don't mind burning a couple hundred extra bucks there's always the SteedSpeed manifold, I doubt you'll get much performance appreciation in a stock truck but they do look nice and have a lifetime warranty.
Postby grinnergetter » Wed Apr 10, 2013 7:51 pm
Thanks again for your experiences and help with the search thing.
grinnergetter
Postby PToombs » Thu Apr 11, 2013 5:23 pm
Back when I bought my ATS I researched all around to find the best flowing manifold. I found a chart, which I just spent 30 minutes looking for and can't find anyplace on the web any longer. It stated that ATS flowed about 32-34 cfm better than stock, and a little (4-5?) better than a BD manifold. I can't remember the exact numbers, which is why I was looking for the chart. Anything is better than stock, and the 3 piece ones can move and won't shrink and crack the ears off the head. I was lucky and got the stock one off without breaking anything. It was over 1/4" short from the bolt holes end to end. I dropped almost 100* going from stock to the ATS.
I don't know if I'd buy another ATS, but it works good!
Postby CumminsPower59 » Thu Apr 11, 2013 5:37 pm
Are there any other options besides BD, ATS, or Steed Speed?
Postby RCCUMMINS89 » Thu Apr 11, 2013 5:56 pm
Diesel Power Source is by far the cheapest at 379????????? retail.
Users browsing this forum: No registered users and 82 guests
