Valet switch parts
Valet switch parts
Postby rbrettctd » Sun Nov 04, 2007 3:22 pm
Where can I get them? I checked out Grainger, as the DTR sticky pointed out, but they have limited supply on many pieces.
Randy
rbrettctd
Postby PToombs » Sun Nov 04, 2007 6:02 pm
I got mine at Graingers. I can't remember the # right away, but I can look at the receipt. I know it is 12 volt, 1/8 pipe thread. It works good. I took a guy for a ride yesterday, wait til 20 psi of boost, and hit the switch. Just like stepping on the pedal again! :hs:
Postby rbrettctd » Sun Nov 04, 2007 6:11 pm
Haha, well I found the solenoid, muffler, and a couple of the connectors, but there was one or 2 that werent in stock or there was only 1 when I need 2. I can make something else work if I have to though. Thanks.
Randy
rbrettctd
Postby PToombs » Sun Nov 04, 2007 6:30 pm
I used 6JJ52. I used the stock line from the solenoid to the AFC, and air brake type plastic hose from the head to the solenoid.
I fabbed a small bracket and mounted the solenoid to the AFC cover screw.
I didn't put a muffler on mine, why bother?
