I just installed a carter 4601 last night along with another filter, here is how the fuel path goes.
from tank in the original line to just past the edge of the tank, then 3/8th rubber to a 10 micron pre lift pump filter,
then the carter 4601, then on to a 2 micron filter and on the original filter/fuel heater on the block, and on the VE
by way of the original metal line.
I have had a holley black, walbro, and now a carter, the carter and holley both should have had 14-18 psi, but neither
one had more than 11 (the holley) the carter only has 9psi at idle and drops to 6 at WOT run.
besides putting on a mechanical pump, is there something I am doing wrong that I could change.
has anybody ran a 4601 and had higher psi.
