ve cam plate???
ve cam plate???
Postby ford69557ci » Mon Nov 05, 2007 4:59 pm
does anybody know what the factor lift on the ve cam plate is??my digi calipers quit workin and i need a measurement. thanx
ford69557ci
Postby oldestof11 » Mon Nov 05, 2007 6:07 pm
If you are thinking what I think you are doing, lemme know how it works. I have been studying really hard how the VE work internally. I have some stuff in mind that I might try.
Postby ford69557ci » Mon Nov 05, 2007 7:42 pm
well i am goin to get a higher lift plate i already have the 14mm h and r i will be tryin to feed fuel through the shut off my pump case has some serious flow improvements. I am also checkin in to getting a larger set of injector lines made. but first i need to know the plate lift cuz snap on is bein slow about fixin my calipers
ford69557ci
