turbo specs
turbo specs
Postby BILTIT » Mon Apr 22, 2013 2:47 pm
Didnt see this anywhere on the site so i thought i would bring it over from CompD.
Borg Warner
S200
Turbine Wheel
61.5/69.5
64/74
Comp Wheel
56/80-----58lbs/min
59/80-----61lbs/min
Housings
T3 .55, .70, .76, .85
S300
Turbine Wheel
65/xx, 68/76, 71/80, 73/80
Comp Wheel
57/83--------61lbs/min
60/84.5
62/88--------72lbs/min
63/87
64/92.5
66/91.5------76lbs/min
71/105.5-----86lbs/min
Housings
T3 .55, .70, .85
T4 .83, .88, .91, 1.00, 1.10, 1.25
K31
Turbine Wheel
74/83
Comp Wheel
71/100-------95lbs/min
Housings
T3 .76
T4 .85, 1.0, 1.10
S400
Turbine Wheel
74/83, 77/87, 80/87, 82/87, 82/92, 88/96
Comp Wheel
66/100
71/100-----89lbs/min
75/100-----100lbs/min
76/107-----104lbs/min
78/110
80/116-----120lbs/min
83/119
88/xx
91/xx
Housings
T4 1.0
T6 .90, 1.10, 1.32, 1.51
S500
Turbine Wheel
99/110
Comp Wheel
80/xxx
86/xxx
88/121.5-------145lbs/min
91/121.5-------155lbs/min
95/131.5-----160lbs/min
98/xxx
Housings
T6 .85, 1.00, 1.15, 1.45, 1.60
Holset
HX30
Turbine Wheel
52/65.5
Comp Wheel
44/73--------45lbs/min
Housings
T3 6cm
HY35
Turbine Wheel
58/65
Comp Wheel
54/78----58 lb./min 7blade
Housings
T3 9cm
HX35
Turbine Wheel
58/70
Comp Wheel
54/83
56/83-----52lbs/min
60/86-----62lbs/min
62/86
Housings
T3 12cm, 14cm, 16cm, 18cm, 21cm
HX40
Turbine Wheel
64/76
Comp Wheel
58/83
60/83
60/86-----62lbs/min
62/86
Housings
T3 16cm, 18cm
T4 16cm, 17cm, 18cm, 19cm, 21cm
HE341
Turbine Wheel
58/65
Comp Wheel
54/xx
Housings
T3 9cm
HE351
Turbine Wheel
58/65
Comp Wheel
60/86-----65lbs/min
Housings
T3 9cm
HX50
Turbine Wheel
Comp Wheel
62/99
66/99
67.5/99
71/99
Housings
HX52
Turbine Wheel
70/84
Comp Wheel
64/99
66/99
67.5/99
71/99
Housings
T4I 16cm, 25cm
HX55
Turbine Wheel
73/xx
77/86
80/86
Comp Wheel
66/98
67/99
65/100
72/xxx
Housings
T6 19cm, 22cm, 25cm
HT3B
Turbine Wheel
86/97
Comp Wheel
73.5/109
Housings
T6 23cm, 26cm, 32cm
HT60
Turbine Wheel
81/94
Comp Wheel
74/105.5
80/112
Housings
T6 26cm
HX60
Turbine Wheel
86/97
90/97
Comp Wheel
76/102
80/113
Housings
T6 23cm, 27cm
HT4B
Turbine Wheel
88/118
Comp Wheel
83/127
88/139
Housings
T6 26cm
HC5A
Turbine Wheel
Comp Wheel
87.5/127
88/139
Housings
T6 41cm
HX82
Turbine Wheel
94/126
Comp Wheel
82/141
90/141
95/152
99/141
103/152
105.5/141
110/151
116/151
Housings
T6 22cm, 25cm, 32cm, 36cm, 41cm, 48cm
Garrett
GT35
Turbine Wheel
62/68
Comp Wheel
61.5/82-----67lbs/min
62.5/82.5---75lbs/min(GTX)
Housings
T3 .63, .82, 1.06
T4 .63, .82, 1.06
GT37
Turbine Wheel
64/72.5
Comp Wheel
55/76-------50lbs/min
59/82-------56lbs/min
63.5/88-----68lbs/min
65/88------ 71lbs/min
68/94-------80lbs/min
Housings
T3 .89, .99, 1.11
T4 1.12
GT40
Turbine Wheel
68/77
Comp Wheel
65/88-------71lbs/min
Housings
T4 .85, .95, 1.06, 1.19, 1.34
GT42
Turbine Wheel
75/82
Comp Wheel
70/94------84lbs/min
70.5/94----98lbs/min(GTX)
75/102-----96lbs/min
76/102-----114lbs/min(GTX)
Housings
T4 1.01, 1.15, 1.28, 1.44
T6 1.01, 1.15, 1.28
TV4502
Turbine Wheel
78.5/85.5
Comp Wheel
65.5/91
Housings
T6 1.22
GT45
Turbine Wheel
80/87
Comp Wheel
80/108------112lbs/min
80/108------127lbs/min(GTX)
Housings
GT47
Turbine Wheel
84/93
Comp Wheel
88/118------140lbs/min
Housings
T6 .96, 1.08, 1.23, 1.39
GT50
Turbine Wheel
91/99
Comp Wheel
81.5/118
Housings
TV8401
Turbine Wheel
97/108
Comp Wheel
84/117
Housings
T6 1.23
GT55
Turbine Wheel
102/111.5
Comp Wheel
84/123
88/118-----165lbs/min(GTX)
89/118.5---145lbs/min
91/133-----153lbs/min
91/133-----167lbs/min(GTX)
94/133-----160lbs/min
94/133-----181lbs/min(GTX)
106/141----185lbs/min
Housings
T6 1.0, 1.18, 1.24
GT60
Turbine Wheel
118/129.5
Comp Wheel
98/141
106/141-----185lbs/min
Housings
T6 1.25
G-Trim
Turbine Wheel
111/130
Comp Wheel
Housings
F-Trim
Turbine Wheel
106/130
Comp Wheel
Housings
Derek B.
BILTIT
Re: turbo specs
Postby Douglas » Fri Sep 20, 2013 6:14 am
Some missing info; the Hy35 and HX35 54/78 compressor is the 7-blade rated at 58 lb./min. Nothing stopping you from adding 18 and 21 cm housings to the HX35 either as they're the same as the H1C's.
cheers,
Douglas
1991 D250, 727 and 16cm H1C.
Douglas
Re: turbo specs
Postby BILTIT » Fri Sep 20, 2013 7:20 am
Added, thanks.
Derek B.
BILTIT
