D-dog357 wrote:Do you think that size turbo would control the smoke from 5X12's ?
Remps wrote:If mileage is a priority 190's or maybe a 5x10 injector would be good. Although I think 5x12's would work if you tuned the pump to not push more than 30ish psi boost. I think if you never plan on going bigger than an hx35, the 5x12's aren't needed. Doesn't Philip tow with 6x16's and an HX40? I doubt his pump is turned up at all.
D-dog357 wrote:
Looks like I might have a set of 5X12 nozzles up for barter if this turbo wont keep the smoke in check.
