5.9 Cam Timing Events
Postby mhuppertz » Fri May 10, 2013 2:34 pm
Anyone have the cam event specs for a stock 12 valve cam? I need to input those into PipeMax in order to calculate the ideal header length.
Thanks!
mhuppertz
Re: 5.9 Cam Timing Events
Postby Bersaglieri » Wed Nov 21, 2018 12:18 pm
I was searching for these specs as well with no luck. Not necessarily all the events, but the basics like advertised duration, lobe lift, LSA, ICL.
I read that the VE cam and even the NonIC cam were "better" than other 6BT and ISB factory cams. Here is what Colt has on their website:
159/204 @ .050 .235/.263 102 LSA Stock 2nd Generation 12V 1994-1998.5
159/206 @ .050 .235/.297 107.5 LSA Stock 2nd Generation 24v 1998.5-2002
Not sure if 1st Gen cams are the same and 2nd Gen 12v cams.
1997 Ram 2500 P7100 6BT - G56 - Dana
2002 Excursion VE 6BT- Allison - Sterling
Bersaglieri
Postby mhuppertz » Wed Nov 21, 2018 12:30 pm
Thanks.
I guess if I ever pull it apart I can degree the cam and verify the specs. Judging by that duration the lift is probably pretty low.
mhuppertz
Postby Bersaglieri » Wed Nov 21, 2018 12:40 pm
Lift at the valve on that 12v cam would be .411/.460 with a 1.75 rocker.
Bersaglieri
Postby Bersaglieri » Wed Nov 21, 2018 12:43 pm
Without intake centerline and advertised duration I can't calculate intake and exhaust valve events. Wallace Racing has alot of useful calculators for this stuff. Simple no frills website.
Bersaglieri
