i used a 4 oz ball peen hammer
i think the quality of the punch has something to do with it
they do go back in easier than they come out
dont they...
Begle1 wrote:DTanklage wrote:dude, if you remove the top (that takes about what?, 5 mins?) all you do is put a socket or pc of pipe on the back side and knock one of the balls out with a punch. then you turn it over and hit it again and the other one falls out
then you pull the shaft, put it back in, tap the balls back in - and your done
That can be eaisier said than done. I pounded on my ball bearing for 20 minutes with a 4 pound sledge and punch before it even budged. I don't know how ball bearings can get that tight, but they can get wedged in there pretty good.
You definitely don't just tap them out. You gotta beat the crap out of them.
KBdiesel wrote:Damn, your lucky not to bust the top housing. I know mine were pretty easy to pop out, I used a small ball peen hammer too.
Users browsing this forum: No registered users and 62 guests
