Motor mounts
Motor mounts
Postby GPSMatt » Wed Nov 07, 2007 11:08 pm
I know before i took the cummins out for the F 350 I broke both motor mounts along with getting the trans stuck in 4th i prety much beat the truck i need to order material to build the motor mounts for putin the cummins in my ford i have heard bad stuff both about the ford cummins mounts and the autoworld mounts i have made motor mounts for gas engines before using a polyurethane isolator somthing like this... Image
would that be enough isolation
86 F350 idi
85 F350 crew cab 4x 5.9
95 Lightning
85 GT
GPSMatt
Postby DTanklage » Thu Nov 08, 2007 12:26 pm
dunno
they sure would be nice and strong tho...
and it wouldnt be as bad as solid ones
DTanklage
Postby GPSMatt » Thu Nov 08, 2007 4:06 pm
yeah solid would be rediculus on a diesel motor...
86 F350 idi
95 Lightning
85 GT
GPSMatt
Postby DTanklage » Thu Nov 08, 2007 7:15 pm
ahhh, solid wouldnt be that bad...
you would just have to put a plastic guard in your mouth so your teeth wouldnt shatter if you wanted to drive to the grocery store and back
lol
DTanklage
Postby dpuckett » Thu Nov 08, 2007 7:33 pm
They put the 5.9 in F650/750 trucks. If the frames are the same width, the stock mounts from that application may work. Long shot, but worth a try.
DP
Postby GPSMatt » Thu Nov 08, 2007 9:01 pm
the f650 sits on a kw frame as far as I kno I can but the mounts or make new lates for the frame for stock cummins ones to fit but if I destroyed stock mounts on a stock motor then once its built I will destroy them again I either solid mount or run some sort of aftermarket mount on all my sthi caus they always break I have made mounts like the ones in the pic just don't know if it will isolate enough for when I dstroy tire all the way to the grocery store don't wanna wear the plastic guard in my mouth haha
86 F350 idi
95 Lightning
85 GT
GPSMatt
