Twins (Compounds) Build!
Postby PToombs » Tue May 28, 2013 5:31 pm
Ok, I spent some time this spring and made a little up grade. First I did this,
Then I made this,
And this,
And installed them,
Re: Twins (Compounds) Build!
Postby PToombs » Tue May 28, 2013 5:38 pm
Then I put on this big spinney thinger,
Then I ran the exhaust pipe back and around, I ended up using 2-90* and a 45* bend, less bends is less restrictions. ;) I then fabbed up the pressure pipe, with a boot from Silicone Intakes.com,
Postby PToombs » Tue May 28, 2013 5:41 pm
Then an AFE filter from Summit, some wiring and plumbing adjustments for my air compressor and overflow bottle, and we're ready to go!
Postby Tacoclaw » Tue May 28, 2013 5:47 pm
Aaaaaaaaaaaaaaaaaaaaaaaaaaaaaand?
How's it run? :mrgreen:
Postby AHineman » Tue May 28, 2013 5:49 pm
Looks good. It's about time you posted some pics. Now let's see some videos of it running. :twisted:
Postby PToombs » Tue May 28, 2013 6:15 pm
Not enough fuel. :lol: I have done no tuning yet, and not quite sure how. With the valet switch off, not even noticeable. With it on, when it winds up, it suddenly hits and seems to get right with it. Only getting about 35psi of boost at the intake, not sure what I have from the big turbo. I need to get the gauge mounted so it's not rolling around on the floor, it's hard to read! :mrgreen: I haven't looked at EGT's when I'm on it, cruising I can't compare because it was only 50* out. I need to drive it more and watch it so I have more info.
Postby Tacoclaw » Tue May 28, 2013 6:20 pm
PToombs wrote:Only getting about 35psi of boost at the intake, not sure what I have from the big turbo.
Dun dun duuuuuuuuuuuuuuuuuuuuuuun. And so it starts, didn't you make more than 35 with just a single?
Postby oldestof11 » Tue May 28, 2013 7:39 pm
Man, how can the guys tell it's you when you start heading to SOP from the hotel? You could have heard that thing miles away...
Postby BC847 » Tue May 28, 2013 8:02 pm
Nice. 8)
What's your waste-gate set at?
Postby Tacoclaw » Tue May 28, 2013 8:17 pm
I'm thinking boost leak. :jumpsmile:
Postby dunes450r » Tue May 28, 2013 8:51 pm
good work! might need to heat wrap your pipe between the two compressors huh? lots of heat comin off the manifold
dunes450r
Postby Deathrod » Wed May 29, 2013 5:35 am
looking at your low pressure turbo brace, it kinda of is built like the first one I built. Mine was solid and it felt like I could stand on it with no problems. However with mine in drive it had this slight vibration that looked like it couldnt be good on the bearings. Not sure if yours is an auto but if not find a way to put load on it with the hood up and see if you got the shakes!
Deathrod
Postby Sutter1stgen » Wed May 29, 2013 6:17 am
Did you run a ball hone or something of the like through the piping after you welded it?? Friend of mine didn't and had to replace his secondary compressor wheel.
Eric
Sutter1stgen
Postby BILTIT » Wed May 29, 2013 8:11 am
Is it loud with an open filter like that? I have compounds in my near future but don't want alot of excessive noise, i am comparing to my 351cw with stock intake setup and 2" holes drilled in the filter box.
Derek B.
BILTIT
Postby rockbuggy4x4 » Wed May 29, 2013 2:31 pm
Sweet! looks awesome. Hope you get it working right so we can see some numbers. :lol: Which turbos did you use?
Jimmy
--> '95 jimmy not so stock
rockbuggy4x4
