FINALLY put in my AFC spring (the stiff one)
Postby RCCUMMINS89 » Wed Jun 05, 2013 11:09 am
:roll:
After I've had my customers test them and 6 months later I finally took my pump off to fix the rounded off bolt so I could get my afc top off to fix the afc lever/slide pin issue. :lol:
My AFC spring is well......................stiff.
With a modified stage 1 Denny Pin (not my first choice for sure) and the starwheel the right side up and about 3/4 of the way up, I can only hit 32 psi and 1050 degrees...... boy howdy is she a good running truck that way, especially with the 3800 spring. :shock:
Point being, I can achieve full boost with it bottomed out but the spring is stiff enough to hold back well over 40psi from my testing.
Now for those who don't ahve that much boost, this spring is designed in a way where we can shorten it as need be.
Re: FINALLY put in my AFC spring (the stiff one)
Postby sshort » Sat Jun 08, 2013 7:08 pm
I just installed mine that I got from you and I like it a lot. It seems to pull a lot harder through the power band. Also switched to the 4200 rpm spring this is like night and day difference
1991 D350 ddpstg3 injectors pump mods trans mods 63-68-12 turbo water/meth & nitrous
sshort
Postby RCCUMMINS89 » Sat Jun 08, 2013 7:20 pm
Glad to hear you like it.
Postby 93 W350 LE » Mon Jun 10, 2013 11:00 am
RCCUMMINS89 wrote::roll:
Starwheel right side up????? Can this be flipped from stock, or something? Please explain.
Thanks.
Eric
93 W350 LE Club cab dually automatic, Banks Power Pack w/ exhaust, Banks tach and pyrometer, Isspro boost gauge, GearVendors O.D., BD exhaust brake, Kelderman Compuride and front bags. My Dad was the 2nd owner.
So far; rotated fuel pin, bottomed star,1/2 turn on smoke screw.
Daily driver and occasional 14k lb 5th wheel hauler.
Thank a veteran for your freedoms!
93 W350 LE
