I am finally getting my Snow Performance fabbed up, but was wondering what nozzles others are running.
I have one of the 625ml nozzles which is the largest Snow makes.
skilletky wrote:. with my new controller set to 100%, it causes the engine to buck.
ellis93 wrote:skilletky wrote:. with my new controller set to 100%, it causes the engine to buck.
What do you mean?
BC847 wrote:ellis93 wrote:skilletky wrote:. with my new controller set to 100%, it causes the engine to buck.
What do you mean?
Too much W/M at that rpm or part-throttle. It's trying to put the fire out.
I run two .625 nozzles on my mess.
What do you mean?
DMan1198 wrote:If my logic is sound you could install the nozzles pre-intercooler and not worry about it pooling if you make sure you blow good boost pressure through it. Also maybe set it to come on at just a bit higher boost
