question
question
Postby cummins king » Mon Nov 12, 2007 8:09 pm
if i got bigger injector lines that fit second gen injectors but still fit the ve pump and i got second gen injectors would the injectors fit in the motor proprly
93 4X4 auto
cummins king
Postby oldestof11 » Mon Nov 12, 2007 8:23 pm
Yes they will fit BUT the pop pressure is much greater in a 2nd Gen than our 1st Gens.
Postby cummins king » Mon Nov 12, 2007 8:38 pm
so is it possible to reduce the pop pressure in the second gen injectors
93 4X4 auto
cummins king
Postby PToombs » Tue Nov 13, 2007 6:23 pm
Yes, just reshim 'em! ;-)
Postby cummins king » Tue Nov 13, 2007 6:39 pm
how do u e shim them
93 4X4 auto
cummins king
Postby ford69557ci » Tue Nov 13, 2007 9:36 pm
you dont want to run larger injector lines on you 12mm pump and you really dont wanna run them if you tow or drive in any kind of traffic really crazy idle touchy throttle and lots of low end smoke
ford69557ci
Postby cummins king » Tue Nov 13, 2007 9:49 pm
ya i kind of knew that but thanks
93 4X4 auto
cummins king
Postby PToombs » Wed Nov 14, 2007 6:08 pm
You need a pop tester. Easiest thing is take them to a pump shop. They can get them close on the first try, since they do them all the time, plus they have the shims. ;)
I've never messed with taking an injector apart, just so ya know. ;-)
Postby DTanklage » Thu Nov 15, 2007 2:04 pm
i took one apart
there is nothing to them
and the shims are avail thru cummins (and i am sure most shops that do inj have them too)
but - if you dont have a pressure tester the shims wont do you any good
DTanklage
Postby flashgordon » Thu Nov 15, 2007 3:18 pm
DTanklage wrote:i took one apart
I have one at work BUT they must make a lot better ones, because the only thing this ones good for is to check a dribbling inj :bball: :lol:
I wouldn't be able to tell if the shim improved the pressure or not...........I couldn't even tell yeah if the Pressure were the same with a stock set of injectors.
You need one that has "0" bleed down and this one.........well it bleeds down.
Flash.
flashgordon
