Ok so last night I descided to install my 366 spring. I was using this as a guide:
http://dens-site.net/Dodge_CTD/Governor ... index.html
and I get down to the part where you move the low idle screw and remove the rear allen bolt........ and that is where it all stopped.. His picture shows about 3/4" of clearance between the AFC and the intake plate (or more)... I might have 3/16" if you really stretch it... so is my timing advanced that far????
At any rate, how do I get to those two items without any room? I thought about rotating the pump towards the fender, but I couldn't get to the top bolt on it either...
Any help would be appreciated..
On a side note: adjusted the star wheel, turned and ground a little on the pin.... WOW! should have done that a long time ago.. so much snappier..
*edit* I will try to snap a pic this evening..
