by flyin6 » Sun Feb 09, 2014 7:38 am
I use Amsoil stuff in my trucks. Was just ordering some oil, and came across this abundance of information which I thought I'd share:
LUBRICANTS & FLUIDS:
Engine Oil
Grade 1......CF-4
SAE 15W-40 Synthetic Heavy Duty Diesel and Marine Motor Oil (AMEQT)
Synthetic 15W-40 Diesel Oil (DMEQT)
Synthetic 15W40 OE Diesel Oil (OEDQT)
-9 To 10 F......10W-30 [1]
Above 10 F......15W-40
Below 0 F......5W-30, 10W-30
Manual Transmission,G360 (5-SPD)......SJ
All TEMPS......5W-30
SAE 5W-30 Signature Series 100% Synthetic Motor Oil (ASLQT)
XL 5W-30 Synthetic Motor Oil (XLFQT)
OE 5W30 Synthetic Motor Oil (OEFQT)
Automatic Transmission,A500......AP4
Signature Series Multi-Vehicle Synthetic Automatic Transmission Fluid (ATF) (ATFQT)
OE Multi-Vehicle Synthetic Automatic Transmission Fluid (OTFQT)
Automatic Transmission,A999(32RH)......AP4
Automatic Transmission,A998(31RH)......AP4
Automatic Transmission,A518(46RH)......AP4
Differential, Front Spicer 44......GL-5
All TEMPS......80W-140, 85W-140, 80W-90
SEVERE GEAR 75W-140 Synthetic EP Lubricant (SVOQT)
80W-140 Synthetic Long Life Gear Lube (FGO05)
Differential, Front Spicer 60......GL-5
Limited Slip Differential, Rear Dana 60......GL-5*
All TEMPS......80W-90 [2] [3]
SAE 80W-90 Synthetic Gear Lube (AGLQT)
SEVERE GEAR 75W-90 Synthetic EP Lubricant (SVGQT)
75W-90 Synthetic Long Life Gear Lube (FGRQT)
SEVERE GEAR 75W-110 Synthetic EP Lubricant (SVTQT)
Limited Slip Differential, Rear Chrysler......GL-5*
Limited Slip Differential, Rear Dana 70......GL-5*
Transfer Case,NP241LD......AF2
Torque-Drive Synthetic Transmission Fluid (ATD1G)
Transfer Case,NP208......AF2
Transfer Case,NP208......AF3
Transfer Case,NP208......AP3
Transfer Case,NP241HD......AF2
Transfer Case,NP241HD......AP3
Transfer Case,NP241LD......AP3
Transfer Case,NP241HD......AF3
Transfer Case,NP241LD......AF3
Transfer Case,NP205......GL-5
Above -9 F......90
Transfer Case,NP205......SJ
Above 32 F......50
Synthetic Powershift Transmission Fluid SAE 50 (CTL05)
Above 90 F......140
No AMSOIL Product Recommendation
Below -9 F......80W
Below 32 F......30
Formula 4-Stroke® 10W-30/SAE 30 Small Engine Oil (ASEQT)
Fluids
Clutch Fluid......HB
AMSOIL Brake Fluid DOT-3 (BF3SN) [4]
Power Steering Fluid......PS
Power Steering Fluid (PSFCN) [5]
Brake Fluid......HB
[1] SAE 10W-30 recommended below -18 C (0 F) with block
heater only.
[2] Limited Slip Identification: Lift both rear wheels,
turn a wheel and other will rotate in same direction.
[3] With controlled slip, add 6.5%
Mopar Trac-loc additive or equivalent
[4] Hydraulic Brake Fluid, DOT 3
P/N 04318080AB or 04318081AB, meeting MS-4574
[5] Mopar P/N 4883077, Spec No. MS5931
FILTERS:
Oil Filter 25,000-Mile Ea Oil Filter (EAO80)
Oil Filter WIX 51607 Oil Filter
Fuel Filter WIX 33379 Fuel Filter
Transmission Filter WIX 58707 Trans Filter
NGK PLUGS AND WIRESETS:
No Recommendations
WIPER BLADES:
Blade Class
Driver
Passenger
ExactFit T181
ExactFit T182 T182
ExactFit T181
NeoForm T16180 T16180
Winter T37180 T37180
CHASSIS LUBRICATION:
CAPACITIES:
Engine, with filter..........13 quarts [1]
Cooling System, AT Initial Fill..........17.4 quarts
AMSOIL Antifreeze and Engine Coolant
Cooling System, MT Initial Fill..........16.4 quarts
Automatic Transmission, A500 Initial Fill..........4 quarts
Automatic Transmission, A518(46RH) Initial Fill..........4 quarts
Automatic Transmission, A998(31RH) Initial Fill..........4 quarts
Automatic Transmission, A999(32RH) Initial Fill..........4 quarts
Automatic Transmission, Total Fill
4 speed A518(46RH)..........10.1 quarts
3 speed A999(32RH)..........8.6 quarts
4 speed A500..........10.1 quarts
3 speed A998(31RH)..........8.6 quarts
Manual Transmission, G360 (5-SPD)..........7 pints
Differential, Spicer 44 Front..........5.7 pints
Differential, Spicer 60 Front..........6.6 pints
Differential, Chrysler Rear..........4.4 pints
Differential, Dana 60 Rear..........5.9 pints
Differential, Dana 70 Rear..........7 pints
Transfer Case, NP241HD..........5.9 pints
Transfer Case, NP205..........4.4 pints
Transfer Case, NP208..........5.9 pints
Transfer Case, NP241LD..........4.6 pints
[1] After refill check oil level.
TORQUES:
Oil Drain Plug.....44 ft/lbs
Manual Transmission G360 5-SPD
Fill Plug NA ft/lbs
Drain Plug NA ft/lbs
Manual Transmission
Fill Plug NA ft/lbs
Manual Transmission 5-SPD
Fill Plug 30 ft/lbs
Drain Plug 30 ft/lbs
Manual Transmission A833 4-SPD
Fill Plug 15 ft/lbs
Drain Plug 35 ft/lbs
Manual Transmission NP435 4-SPD
Fill Plug 35 ft/lbs
Transfer Case NP205/241
Fill Plug 40 ft/lbs
Drain Plug 40 ft/lbs
Transfer Case NP208
Fill Plug 18 ft/lbs
Drain Plug 18 ft/lbs
1991.5 RCLB 7" lift, 1" body lift, P-pump motor, cut delivery valves, 4K spring, ARP, 3.54, Sterling axle Lock Rite, 6" skyjacker 37" MTR's recentered HMMV wheels. Traction bar, boxed in frame, Hydro assist brakes, dual batteries, elec air pump, lift pump, extra filter, 3-piece manifold, Diamond 4", 4" driveshaft, X-over steering, isspro tach, EGT, boost, and more...
