turbo
turbo
Postby cummins king » Fri Nov 16, 2007 9:10 pm
NEW T3/T4 B TURBO
48 AR STAGE III
60 COMPRESSOR
does anybody know what this is and if its any good for twin set up
thanks
93 4X4 auto
cummins king
Postby ford69557ci » Fri Nov 16, 2007 9:12 pm
small turbo would be good for a b series honda or a 2.0 eclipse
ford69557ci
Postby cummins king » Fri Nov 16, 2007 9:24 pm
thanks again
93 4X4 auto
cummins king
Postby ford69557ci » Fri Nov 16, 2007 9:42 pm
no prob is that an ebay turbo?
ford69557ci
Postby cummins king » Fri Nov 16, 2007 9:45 pm
ya i found a good deal on a new hx 55 though
93 4X4 auto
cummins king
Postby ford69557ci » Fri Nov 16, 2007 10:36 pm
you gotta watch those off brang ebay turbos i had a set of twin 72mm off brands i got from ebay and on my s 10s first run the compresso wheels exploded filling my 20 000 dollar engie full of metal chunks in the burnout box. kinda embarrasing. :oops: an hx 55 would be good for twins but a 60 would be even better. there is a place on ebay sellin s475's with a warranty for under 700 bucks
ford69557ci
Postby cummins king » Sat Nov 17, 2007 4:22 pm
thx but i wouldn't buy any of brand turbo
what do think of this turbo
Holset HT 80 Turbo-903 Cummins-Big Cam-OUTLAW TTP
93 4X4 auto
cummins king
Postby ford69557ci » Sat Nov 17, 2007 4:34 pm
an ht 80 is a very large turbo like p pump engine with 1200hp style
ford69557ci
Postby cummins king » Sat Nov 17, 2007 5:03 pm
ya its a huge turbo
on the hx40 how much better is the six blade over the 8 blade on the intake side
thanks
really apriciate picking your brain mr. ford
93 4X4 auto
cummins king
Postby ford69557ci » Sat Nov 17, 2007 5:54 pm
i have never had a hx40 on a cummins but i did run one on an eclipse that i built. what i found on the dyno with that engine was the 6 blade spooled slower but made more top end power and the eight blade spooled faster but made less on the top. hope that helps
ford69557ci
Postby cummins king » Sat Nov 17, 2007 6:02 pm
ya it helps
i would need the 8 blade for faster spool becuase i got the new hx 60, witch is almost in the mail
you know what really blows my mind, you can buy a new hx 60 and an hx 35 or hx 40 for around a 1000ish, and get a hot pipe made up for 200ish and few other small things, but when your all said and done it might only cost you 1500 or if you really shop 1000 bucks, how can ats and bd and those guys sell twin systems for 3500 to 5000 its just crazy and they get all the parts cheap too.
and what exacly is a t3 flange
93 4X4 auto
cummins king
Postby cummins king » Sun Nov 18, 2007 12:17 pm
whats the difrence between an hx 60 and a HT3B and what vehile could you find a hx 60 or a ht3b on
thank
93 4X4 auto
cummins king
Postby ford69557ci » Sun Nov 18, 2007 12:29 pm
the ht3b were on alot of big cam cummins and i am not really sure what the hx60 would be on im guessin probly somethin like an n14???
ford69557ci
Postby ford69557ci » Sun Nov 18, 2007 12:30 pm
oh yeah a t3 flange is just the size of the bolt pattern that bolts the turbo to the manifold goes all the way from t 3 to t 6
ford69557ci
Postby cummins king » Sun Nov 18, 2007 12:40 pm
thanks again, im going to a truck scrap yard hopfluy monday or tuesday and i want to get somthing
whats bigger thouh the hx 60 or an ht3b
is a Borg Warner turbo any good o is it a nock off
93 4X4 auto
cummins king
Users browsing this forum: No registered users and 91 guests
