4200 gsk or more?
Postby Underpsi » Thu Nov 22, 2007 7:42 pm
PToombs wrote:Yup, the crowd was suitably impressed with the carnage! :lol: He said on TDR that one of the spragues or planetaries in the trans stripped, then it went to 7200 rpm. :;-|:
I figured something happened cuz it sounded like it just lost the load on the engine all a sudden and spun a couple extra thousand rpm :evil:
1989 D250 5spd w/SB3250DD, .020 over head gasket, O-rings, Extensive port/polish, ARP head studs, 62/71/14, 6x.018 sticks. First Dyno stock turbo and pods: 343/879
2nd with 62 & big sticks: 393/813
Underpsi
Postby ford69557ci » Fri Nov 23, 2007 10:35 am
yeah that sucks. i have seen videos of his truck pullin and he damn near drags it off the track every time
ford69557ci
Postby PToombs » Fri Nov 23, 2007 4:38 pm
He was selling bearing caps and rod parts as souveniers for a while! :lol:
Postby bgilbert » Sun Nov 25, 2007 3:15 pm
THE TANK1 wrote:I was just asking if the ve could turn more then 4200. The bottom end is done.
Yes no load it will. Under load is a different story. I'm not sure how high KTA has had his under load/dyno though. Mine has seen 4k on the dyno.
Bill Gilbert
bgilbert
Postby PToombs » Mon Nov 26, 2007 7:49 pm
Mine has gone 3700, nothin left for power though! :x
Postby DTanklage » Wed Nov 28, 2007 10:20 am
i wonder if that is because the vane pump is done at that point?
what would happen if you had a mech pump keeping the case pressure above 150?
then there are the cam specs - 5000 rpm should have totally different specs than a 3000 rpm motor
DTanklage
Postby ford69557ci » Wed Nov 28, 2007 1:32 pm
all in good time my friend lol. if i can ever find a few more core injection pumps for some testing that is.
ford69557ci
Postby dpuckett » Wed Nov 28, 2007 5:36 pm
I've read somewhere that the upper 40s is it for the VE in VW applications, which flow much less than the Cummins applications. I think that is still waaayyy too fast for a diesel.
Daniel
Postby ford69557ci » Wed Nov 28, 2007 5:57 pm
there is no such thing as too much :evil:
ford69557ci
Postby cummins king » Wed Nov 28, 2007 7:27 pm
thats true untill the motor blows up and then its to much
93 4X4 auto
cummins king
Postby Begle1 » Wed Nov 28, 2007 8:36 pm
cummins king wrote:thats true untill the motor blows up and then its to much
That's not a sign of too much. That's a sign of the motor having too little.
Users browsing this forum: No registered users and 65 guests
