water/meth
water/meth
Postby JD91 » Thu Dec 19, 2013 8:38 pm
well im really thinking about putting a water meth injection on my 93 d350 (mods in my sig) worth the investment or not??? What are yall thoughts on it??
91 w250 RC, getrag, 4in turbo back diamond eye
93 D350 CC, getrag, 4in diamond eye, 60# springs,3200 gov,arp's,fass 150,fass sump, BD SUPER B 58MM, 5x14 sticks, M&H timing spacer, cut fuel pin,valair clutch, auto meter pyro & boost......she screams!!
91.5 d350 RC, getrag, cut fuel pin, no bed lol "the beater"
75 dodge club cab swb flat bed 4x4 "gasser" on 37's
JD91
Re: water/meth
Postby RCCUMMINS89 » Thu Dec 19, 2013 9:32 pm
How do you use the truck?
Re: water/meth
Postby JD91 » Fri Dec 20, 2013 8:25 am
Mainly for work right now. Pulling trailers and stuff like that, but when it's not hooked up for work. Racing punk kids in their new pickups.
JD91
Re: water/meth
Postby skilletky » Fri Dec 20, 2013 1:10 pm
do it. you will enjoy it. i loved mine. what kit are you looking to get?
skilletky
Re: water/meth
Postby JD91 » Fri Dec 20, 2013 7:48 pm
I was thinking snow performance.
JD91
Re: water/meth
Postby skilletky » Sat Dec 21, 2013 12:05 am
I had the stg 3 and loved every bit of it. Cool egts no matter what I was doing, better mpg on the hilly highways, and mo powa (not everyone will experience more power) I ran (2) 625 mL nozzles.
skilletky
Re: water/meth
Postby 1992gen1_fan » Sat Dec 21, 2013 10:54 am
I'f you'll be towing, you'll love water/meth injection. I'm just running a stg 2 "universal" kit and it works good. I'd say a kit actually made for a diesel would work even better. It helps alot with egt's and does add some power when pulling a hill ect. Worth the investment IMO.
1992gen1_fan
Re: water/meth
Postby JD91 » Sat Dec 21, 2013 12:09 pm
Thanks fellas. I'm almost sure ill be running one here shortly.
JD91
