do i need a new i/P
do i need a new i/P
Postby transshop » Fri Dec 27, 2013 12:54 pm
I have a 93 motor in a 05 ford 450 it has scheid 57mm turbo dap 5x12s m3 pin 3200 spring power screw 1/2 turn from all the way in yes coller is off star wheel 1-1-1/2 from bottom smoke screw level with lock nut motor runs great can see 25-30 lbs in lower gears in high gear in lockup empty or towing a 38 foot camper i can hold it on the floor and it will only get 18-20 lbs and 900 - 950 on egt before turbo pin is at full travel i marked it and pulled after a drive not sure what to do next i have a 91 and a 99 cummins both with less mods 91 has all free mods and runs better also this motor only has 50,000 miles on it and sat for 8 years with out running thanks for help
transshop
Re: do i need a new i/P
Postby thrashingcows » Fri Dec 27, 2013 1:51 pm
Not trying to be a d!ck...but some punctuation would make it a heck of a lot easier to read...and figure out what your trying to say.
thrashingcows
Postby dazedandconfused » Fri Dec 27, 2013 5:20 pm
What are you running for lift pump pressure?
Postby PToombs » Fri Dec 27, 2013 6:44 pm
I'm thinking lack of fuel also.
Postby CumminsPower59 » Fri Dec 27, 2013 7:05 pm
X3 on fuel pressure.
Postby transshop » Fri Dec 27, 2013 7:07 pm
I have a DAP piston pump. Have not put a gauge for press yet. What should it be at.
transshop
Postby CumminsPower59 » Fri Dec 27, 2013 7:12 pm
Its probably a Delphi pump, heard those are low, like 7-8 psi output...
Postby transshop » Fri Dec 27, 2013 7:16 pm
PToombs I can't send private messages. I would like to talk to you i live just a few hour's from you. Thanks
transshop
Postby transshop » Fri Dec 27, 2013 7:17 pm
Yes they sent a Delphi pump #hfp702
transshop
Postby dazedandconfused » Fri Dec 27, 2013 7:19 pm
It sounds like you are starving for fuel up higher. You need to out a gauge on it you can watch while under load or a hard run.
Postby transshop » Fri Dec 27, 2013 7:25 pm
If it's low press. what pump would i use.
transshop
Postby CumminsPower59 » Fri Dec 27, 2013 7:53 pm
I'd check out TheHungryDiesel.com, there is a true low pressure, high volume pump, with different output psi...I am running a 15psi unit.
Postby PToombs » Sat Dec 28, 2013 4:33 pm
TS, you need 25 (useful) posts before you can PM. Send me an e-mail if you want, user name on here, @ earthlink.net. Where do you live?
