Hx35 shaft in he351cw
Postby DodgeFreak » Thu Jan 02, 2014 7:52 pm
Okay so. I had The Tacoclaw machine my 351 exhaust housing out to hx35 size. I put a rebuild kit in the 351 (still not sure about the lip on the exhaust side But I'll try it.)
I have a question.... When put the center together you have to put the compressor side together then the exhaust side?? correct?? The compressor wheel when torqued down sets preload on everything??
Reason I ask is, when I put it together I can't get the turbine wheel all the way in. If I leave the oil seal plate off the front I have enough clearance to to spin it.
Re: Hx35 shaft in he351cw
Postby DodgeFreak » Fri Jan 03, 2014 6:13 am
Okay so Apparently lack of sleep from the holidays and traveling isn't the best time to put a turbo together...I think I figured it out. I'll report back later.
Postby Tacoclaw » Fri Jan 03, 2014 7:19 am
The best time for complex, mechanical assembly is when you're drunk. 8)
Postby DodgeFreak » Fri Jan 03, 2014 7:28 am
I have a hard enough time when im sober....plus i dont drink lol
Postby Tacoclaw » Fri Jan 03, 2014 7:32 am
I don't see how you can get anything done then. ;)
GL with the assembly.
Postby PToombs » Fri Jan 03, 2014 7:10 pm
Tacoclaw wrote:The best time for complex, mechanical assembly is when you're drunk. 8)
X12! 8)
Postby DodgeFreak » Sat Jan 04, 2014 2:46 pm
It won't work unless I machine the exhaust housing. the exhaust side of the center is different hight than the hx and it allows the turbine wheel to stick out to much. I assembled the cw center with the hx comp wheel and it spins and looks like that part should work. But when I drop it into the exhaust housing the turbine wheel hits. I haven't put the band clamp on, because A) I forgot it down home, and B) theres no way it clears. I think its close but I'm not sure how close.
