by CumminsPower59 » Sat Jan 04, 2014 3:22 pm
NV4500: bigger bearings, better top cover, smaller gears, fifth gear issue.
Getrag: big gears, small bearings, top cover issues(sometimes).
Honestly, I would just change the ring and opinions out, put some 3.54's in it and be happy. Getrags are good transmissions, just can't bang through the gears hard and keep it overfilled with good lube. You run 3.07's, 5th gear isn't even usable till you're up on the interstate, so it'll be like your still running 4.10's when you're in 4th when running two lane highways. The reason I am running a NV is because I fell into three blown ones for $700, and built one good one out of them. Otherwise I would've sourced a Getrag to run.
