PToombs wrote:Eric, what did you have for a manifold before?
#1, They give you those long bolts and sleeves to allow for the expansion of the manifold. 24 valve trucks and a lot of the newer equipment is set up with them.
#6, It probably flows a lot better. Most of the aftermarket manifolds flow about 38-40 cfm better than the stocker.
#8, It flows better! Gets the exhaust out of the way faster.
X2 on the pics when you get a chance!
