Is a piston driven lp just a p pump lp?
Postby Joecochrane » Fri Jan 17, 2014 10:33 pm
Looking into doing a piston driven lift pump. Are they just a standard second gen pump because if so I got one and I would assume I just need to put a regulator in front of it right?
The driver 02 2500 ho 6 speed 2wd lil lift 35s edge cts hot some injectors and a fass
The toy 87 f350 39.5 tires 180 bus motor 727 trans maxed pump ground pin bumped timing 366 spring hx35 and a lot more in the works.
Joecochrane
Re: Is a piston driven lp just a p pump lp?
Postby Tacoclaw » Fri Jan 17, 2014 10:54 pm
You can either regulate a P-pump LP or put a lower pressure spring in it, which is what the LPLPs are. They're all the volume of the HPLPs without the pressure.
RC sells springs you can put in a HPLP to convert it to a LPLP, then if you ever convert you can just put your old spring in.
I would assume it's a minimum of $50 savings over buying a regulator, let alone all the other fittings and whatnot it takes to put a regulator inline. Then again, I'm running a regulator. It all works the same way.
Postby RCCUMMINS89 » Sat Jan 18, 2014 2:47 am
The Cummins and Delphi low pressure piston lift pumps have smaller plunger than the p pump piston pump.
