rbrettctd wrote:Ya he's pointed out on DTR that the condenser wont work. Between me and the mechanical skills of my dad and brother (former mechanics) and the a/c shop, well make something work or have custom lines made if not.
rbrettctd Why do you have to go with a cross flow radiator? if you do you will most definitely need the turned thurm housing.
For those that don't own a non intercooled truck 89-91.0 we have a couple down side to are trucks.
ONE we have a down flow radiator.....but what makes it even worse is that the inlet..........and the out let of the radiator are on the same side...................so equal flow of the coolant thru the radiator.........well it just don't happen.
TWO We have a stove pipe from the turbo to the intake manifold of the truck.
As far as the intercooler go's i thing it will work just fine if your willing to make or have made custom A/C line............in fact if you go with Custom A/C lines...........you might as well go with the R134 compressor and have the lines to fit it.
The plus side.............Our injector are bigger from the factory, then the intercoolered guys
As far as your shround fitting on a cross flow radiator...........I really don't thing so.
Here is a coupe of pic's of my intercooler installed. look closely at the center bracket.
That bracket will have to be completely remove.....if the A/C is going out front and the intercooler is going against the radiator support.
http://i125.photobucket.com/albums/p58/ ... C01693.jpg
http://i125.photobucket.com/albums/p58/ ... C01698.jpg
