breakes
breakes
Postby cummins king » Wed Nov 21, 2007 9:35 pm
any idea what would be a good replacement hydrobooster (the complete thing thats mounted to the fire wall would be), the whole breake system on my truck sucks
KTA didn't you do somthing like that
93 4X4 auto
cummins king
Postby ford69557ci » Thu Nov 22, 2007 10:11 am
i dont see why so many people have problems with htier factory brakes? all i have is new rotors, turned drums, wagner hd pads and shoes, and a new master cylinder. Unloaded driving stomp on the brakes from 70 and you will go through the windshield pulling a 13000 14000lb boat even on hills with a trailer brake i slow down just as good as my friends 01 dodge dually.
ford69557ci
Postby KTA » Thu Nov 22, 2007 11:33 am
There is a whole thread on here about the hydroboost switch. Try using the "search" feature.
Postby cummins king » Thu Nov 22, 2007 11:40 am
mr ford trade you trucks
Thanks KTA
93 4X4 auto
cummins king
Postby ford69557ci » Thu Nov 22, 2007 12:34 pm
if yours was an x cab shortbed 4x4 auto we would be tradin
ford69557ci
Postby cummins king » Thu Nov 22, 2007 4:29 pm
no regular cab 4x4
93 4X4 auto
cummins king
Postby ford69557ci » Thu Nov 22, 2007 6:38 pm
smae as mine cept mines a getrag
ford69557ci
Postby GO OVRIT » Fri Nov 23, 2007 7:13 am
I never realized people had any problems with the brakes on these trucks. I've had 6 of them and haven't had the first complaint. All of mine except my dually have had a min. of 35" tires and have pulled my Jeeps through the mountains/towns/interstate with no problems.
GO OVRIT
Postby cummins king » Fri Nov 23, 2007 9:15 pm
theres three of us and all of us have crapy breakes
93 4X4 auto
cummins king
Postby PToombs » Sat Nov 24, 2007 12:17 pm
Did you do away with your ABS valve? My rear brakes didn't work for nuthin, pedal was mushy, soft. No amount of adjusting or anything fixed it. I had to replace the rear brake line, so I bypassed the valve above the axle and unplugged the ABS brain behind the glovebox.
WOW! Good brakes, firm pedal, stops quick and straight. Big difference! I recommend this first to anybody with brake problems. ;)
Postby cummins king » Sat Nov 24, 2007 4:09 pm
i replaceed the rear break line but put it back into the place it can out of ur saying to get rid of the abs, IT MAKES SENCE :)
thanks PToombs
93 4X4 auto
cummins king
Postby BC847 » Sat Nov 24, 2007 8:43 pm
I recently replaced all the rubber/flex lines with SS braided and upgraded the rear. The ABS works just fine. :)
Postby cummins king » Sat Nov 24, 2007 10:01 pm
wow nice set up wish i had that kind of money,
hey how do you post pictures i can never figuare it out
thanks
93 4X4 auto
cummins king
Postby GO OVRIT » Sun Nov 25, 2007 6:11 am
Are those caddy calipers? How about the brackets and rotors?
GO OVRIT
Postby PToombs » Sun Nov 25, 2007 7:27 am
That's a sweet brake set up! Couldn't have that here, the salt would have it rusted and hanging after the 1st winter! :cry:
Some people have no problems with their ABS, and swear by it. Others, like me, will never have it again! :D
