Timing adjustments
Timing adjustments
Postby 89cumburb » Tue Feb 25, 2014 6:30 am
I have a 93 intercooled engine I'm doin some work to. I don't know how much to advance the timing. I was going to do 1/8 but now I'm starting to wonder if I should do more 1 tooth or more. I have 5x14 injectors 60# valve springs 3800 gov spring h1c with 60mm compressor housing and a hx55 I'm going to be twinning it.
89cumburb
Re: Timing adjustments
Postby DMan1198 » Tue Feb 25, 2014 7:04 am
If you've got the front cover off anyway then go for the tooth skipped. Then pull the pump as far away from the head as it'll go. That's roughly the same as a 1/8th inch bump. Then you can go from there
Postby RCCUMMINS89 » Tue Feb 25, 2014 7:53 am
^^^agreed^^^
