Steed speed manifold
Postby JD91 » Fri Apr 18, 2014 12:00 pm
I'm lookin to purchase a exhaust manifold and was wonder what y'all thought about the steeds speed
Does anybody run one?
Did you notice a difference?
Worth it?
Any info would be greatly appreciated.
Thanks
John
91 w250 RC, getrag, 4in turbo back diamond eye
93 D350 CC, getrag, 4in diamond eye, 60# springs,3200 gov,arp's,fass 150,fass sump, BD SUPER B 58MM, 5x14 sticks, M&H timing spacer, cut fuel pin,valair clutch, auto meter pyro & boost......she screams!!
91.5 d350 RC, getrag, cut fuel pin, no bed lol "the beater"
75 dodge club cab swb flat bed 4x4 "gasser" on 37's
JD91
Re: Steed speed manifold
Postby DMan1198 » Fri Apr 18, 2014 1:29 pm
I run one
Didn't notice a difference, but I don't have pre turbo egts from before and after
Whether it's worth it or not is up to you
Postby oldestof11 » Fri Apr 18, 2014 5:38 pm
What's your goal?
A stock manifold with a port and polish might be cheaper. However the things I like about Steedspeed is the waste gate mount.
Postby 93flatbed » Wed Apr 23, 2014 3:06 am
Better get it ordered if you want one. I placed my order on March 11th. Still patiently waiting.
93flatbed
Postby RCCUMMINS89 » Wed Apr 23, 2014 6:48 am
IMO, no they are not worth it... except for the gate. I run a steel afe bladerunner. I noticed a little more throttle response, etc.... but my egt gauge actually told me that it made a huge difference at wot.
Postby Kasper Cummins » Wed Apr 23, 2014 7:25 pm
So I never really cared how much they got for one but I just looked it up. :shock: WTF! I could build a few stainless steel headers for that much. Now in my mind steed speed is top of the line and you get what you pay for, but that's alot.
Maybe I should start building headers and intercoolers kits? :grin:
92 W250 club cab
Kasper Cummins
Postby 93flatbed » Wed Apr 23, 2014 8:35 pm
I told myself I was going to build one for the price of one. After I priced out the metal and my hourly wage I was loosing money to build one. Time is a valuable thing when you are as old as I am.
To my knowledge it's the only manifold you can buy that gates all 6.
If I didn't need my external gate then I would not have went with them. I agree the price and wait time is crazy for what it is.
Although there is a reason you see them on lots of the big name trucks. I honestly don't think it's just "because that guy is running one and he always wins" either.
I don't know much though. Just an old man that drinks a bunch. Take my ramblings with a grain of salt.
My buddy with a HPCR truck went with a stainless non gated. It's a nice manifold. Holds the heat in very well. We noticed a difference after it heat soaked and were driving it. He paid 500-550$ for it I think? ones with the gate port add 100$ or so and only gate the rear 3. I so believe I read somewhere that the steed out flows the next closest thing by 10% and a stock manifold by 30%. My head has extensive work done. For the above reasons, and advice from a few guys that build competition trucks, I bit the 790$ price tag and 1-3 month wait time for mine.
93flatbed
Postby RCCUMMINS89 » Wed Apr 23, 2014 9:16 pm
I do notice that with my steel manifold.... that it takes FOREVER for it to come back down to 300 degrees after running. It holds the heat very very well.
Postby JD91 » Mon Apr 28, 2014 8:09 am
Thanks for the comments fellers.
JD91
Postby 93flatbed » Mon May 19, 2014 7:50 pm
Mine showed up. Just over two months. Not the typical wait time. My order form was wrong, not sure if it was my fault. Nevertheless it all got worked out.
93flatbed
Postby JD91 » Thu May 22, 2014 12:54 pm
93flatbed wrote:Image
Have you installed it yet? Did you see a difference?
JD91
Postby 93flatbed » Thu May 22, 2014 8:07 pm
I installed it in my closet with all my other parts. Sorry I won't have any reviews for you for some time. Hope to have my whole build done by years end. I will have changed way too much on the engine to give you a good review. All I can say at this point is that I cost a bunch of money, took lots of time to get. BUT, now that I have it I'm happy I got it.
To be honest I feel it is probably over kill for most of the 1st gen crowd. I'm after something myself so I went with it. They come up used from time to time on other sites, for "cheap" but you have to be Johnny on the spot because they go quick.
93flatbed
Postby v8coupe » Fri May 23, 2014 10:15 am
What gate do people run with these? I'm looking to purchase one of these soon as I have plans of compounds, but I also like the ability to use an external wastegate over the small and restrictive stock Holset setups. I was thinking a 44mm would work I know it'll need a small adapter to fit the larger 2.5" v-band, but that is fine with me.
v8coupe
Postby Tacoclaw » Fri May 23, 2014 11:35 am
I had a 38mm 'gate on mine and boost would stop right now when it opened. A VE engine doesn't turn anywhere rear the RPMs to overwhelm it.
Postby v8coupe » Fri May 23, 2014 2:45 pm
Tacoclaw wrote:I had a 38mm 'gate on mine and boost would stop right now when it opened. A VE engine doesn't turn anywhere rear the RPMs to overwhelm it.
what turbo and boost level. I'm looking to go hx35 as a single for now with plans for compounds later I need a new manifold at the moment so was thinking going with this and a 50mm gate so I have all the base for the compounds.
v8coupe
