indexing
indexing
Postby racerfreak » Thu May 22, 2014 2:49 am
anybody have pictures of proper indexing of throthle levers
racerfreak
Re: indexing
Postby DodgeFreak » Thu May 22, 2014 9:59 am
I'm at work other wise i'd just post the picture but Ike has one, just scroll down to see it.
viewtopic.php?f=1&t=15779
Re: indexing
Postby BC847 » Thu May 22, 2014 2:43 pm
The image DodgeFreak is talking about . . . . .
BUT! . . . . pending what governor-spring you use, you may find it better to go one tick one way, or the other.
For Example, the 3800rpm governor-spring is a little longer that the stock/OEM spring. Perhaps an eighth of an inch longer.
To make the thing work as intended, one could:
A: Shorten the 3800 spring and reshape the end so as to be much like the Stock/OEM spring length.
OR
B: Rotate the throttle-shaft one tick counter-clockwise, so as to take up the slack (if you will), in the internal linkage assembly.
In either case, with completing the above, you'll still want to revisit the main fuel-screw adjustment to dial it all back in.
Re: indexing
Postby RCCUMMINS89 » Fri May 23, 2014 2:57 pm
You mean the 3800? The 3200 is the stock length... isn't it?
Re: indexing
Postby BC847 » Fri May 23, 2014 3:51 pm
Hell, I can't remember anymore, Jane. :oops:
But you're right, the 3800 spring I currently run is about an 8th of an inch longer the stock/OEM.
I edited my post.
;) :lol:
Re: indexing
Postby racerfreak » Sat May 24, 2014 1:10 am
so your saying we should adjust to have a little tension on the spring
racerfreak
Re: indexing
Postby DodgeFreak » Sat May 24, 2014 6:38 am
The 4k spring is longer also. I just reindexed the throttle in stead of clipping it.
Users browsing this forum: No registered users and 68 guests
