BC847 wrote:OK, so the new rear-end is finished. Well over 500 miles on it so everything, after being re-torqued, ought to be seated.
Back to what I was doing when it showed it's @ss.
My injectors are big enough that at WOT, they draw enough fuel volume that the case-pressure is dropping thus retarding the injection event timing while at WOT.
I've been running a simple Walbro-392 through an Aeromotive bypass-type pressure regulator set for 18ish psig. At WOT, that feed-pressure drops to 16ish psig.
Walbro-392 v2.0
ellis93 wrote:Not to side track your tread here but I'd like to know how far your advance drops off by loosing 2psi of supply. ive had hell with my 24v Ve and egt skyrocketing at wot.......and making no power
BC847 wrote:ellis93 wrote:Not to side track your tread here but I'd like to know how far your advance drops off by loosing 2psi of supply. ive had hell with my 24v Ve and egt skyrocketing at wot.......and making no power
Actually, the lift-pump feed pressure dropping is indicative of the case-pressure dropping. It's that case-pressure that powers the timing advance mechanism. IIRC, the case-pressure drops . . . 100psig ? I can't remember atm. I've got data-logger stuff somewhere that clearly shows what's going on with the case-pressure.
Keep the lift-pump supply pressure constant, then deal with the vane-pump, etc inside the IP.
ellis93 wrote:BC847 wrote:ellis93 wrote:Not to side track your tread here but I'd like to know how far your advance drops off by loosing 2psi of supply. ive had hell with my 24v Ve and egt skyrocketing at wot.......and making no power
Guess I should hook up the pressure line to the boost referenced regulator that's on my truck then.
BC847 wrote:
I need to rephrase what I said above. I can't properly address the case-pressure dropping until I can provide the IP with a solid supply. How about that?
I've not done the boost reference line yet. My regulator is maxed to get 20psig.
Remps wrote:That looks sweet, should definitely take care of the 2 psi drop. My guess is it won't affect case pressure a whole lot though. Ellis, aren't you running a 7 hole injector? I thought those didn't make very good horsepower, due to poor penetration at higher rpm/boost. I could be completely wrong, but I think if you pop pressure was 4-500 psi higher one could get better penetration with a 7 hole nozzle and a ve pump. With timing adjusted accordingly of course. K, enough sidetracking, sorry BC.
PToombs wrote:Dave, what are you running for an air filter? I have an Airaid dry type filter and it's not big enough. I would prefer to stick with a dry type, any suggestions?
Have you thought about putting on 1 of the Case breather valve covers?
