JQmile wrote:Hey guys! New here to the board and figured I would say "hi." I own a non-intercooled 89 2wd Dodge that I wanna make go fast, and I also happened to write for Diesel Power Magazine, so it's going to be a project truck. Going from mild to wild so look for all the budget mods first, and the 14mm pump stuff and slicks later. Figured I would let ya'll know so you can follow along if you want since 1st gens don't get much love. So far it's made 200rwhp/408rwtq with DDP 4 injectors and a stock pump (not turned up), through an auto (727).
Thanks for lookin
Jason Sands
Associate Editor
www.dieselpowermag.com
JQmile wrote:Just got back from the dyno.
264/500 with the fuel screw turned in three turns. Got at least a couple more till runaway. Torque is low cause the converter doesn't come in 'till about 1800-2000rpm![]()
I think we'll see close to 300 with a low stall converter and rebuilt trans. (Trans is slipping more and more each pull)
Still stock exhaust, stock air filter, stock everything else.
Jason
JQmile wrote:I think we'll see close to 300 with a low stall converter and rebuilt trans. (Trans is slipping more and more each pull)
Jason
Begle1 wrote:I'd really like to see a hard-core drag build-up running a non-lock-up transmission, personally. I don't think having a high-tech lock-up ATS or DTT in a first gen just really respects the old-school flavor...
JD730 wrote:Begle1 wrote:I'd really like to see a hard-core drag build-up running a non-lock-up transmission, personally. I don't think having a high-tech lock-up ATS or DTT in a first gen just really respects the old-school flavor...
So what flavor does that make my truck?????
