Super B questions
Super B questions
Postby Dan NJ » Wed Oct 22, 2014 9:26 am
So I recently got a super b in exchange for doing some rockers on a friends 2nd gen. My truck has new stock injectors in it and I was thinking about running the afc delete with the super b, anyone have any info? Too much fuel? Too smokey?
93 IC with nv4500
Dan NJ
Re: Super B questions
Postby DMan1198 » Wed Oct 22, 2014 3:03 pm
Don't do an afc delete. Especially if you want to run a big charger. Remember that smoke is heavy, and actually hurts spool up
Postby CumminsPower59 » Wed Oct 22, 2014 4:08 pm
AFC deletes are a joke, before you spend the money, but want to see for yourself how it works, you can pull the AFC lever out of the pump top for $free.99. I pulled the lever out once, just to see what all the hype was about...turned it into a total turd. Lost all the spool, lost 8lbs of boost, and just made it a smokey mess. Having a functioning AFC will help with tuning and drivability hand over fist.
Postby AHineman » Wed Oct 22, 2014 7:05 pm
I don't think the afc delete is a good idea...
As for the turbo, as long as you have the super b and not the super b special, it should be awesome. I've never ran one as a single, but you shouldn't have to ever get rid of it if you upgrade your fueling because it's an awesome secondary for twins.
Postby Sutter1stgen » Thu Oct 23, 2014 4:17 am
Like stated above. Don't delete the afc.
As far as a superB… best little single a guy could ask for on a first gen. Make for a hRd hitting mid range that improves on a hx35 for all around cooling and performance.
Eric
Sutter1stgen
Postby Dan NJ » Fri Oct 24, 2014 7:09 am
Awesome thanks guys I really appreciate the info
Dan NJ
