Fuel supply idea
Fuel supply idea
Postby ellis93 » Mon Dec 08, 2014 2:17 pm
I've a thought :bom:
I have been thinking on fuel supply pumps for a system I'm building,doesn't matter what for,just need a lot of it. Problem is.....its Christmas time. That means more money is flowing than usual,and i need to do something now.....and no money to do it. So.....I have these supper duty ferd pumps sitting here with nothing to do and no problems with them other than folks wanting them changed because they thought that's what the problem was.(turned out that the fuel sending units screens were stopped up....5 so far this year)
My question here is if I was to run two together,parallel,would that increase volume and pressure? Or could I run them in series,and achieve the same thing for volume but keep my pressure the same?
Give me your thoughts on it! :lol:
Re: Fuel supply idea
Postby RCCUMMINS89 » Mon Dec 08, 2014 2:49 pm
In series increases both pressure and volume....
Parallel would keep pressure the same, but increase volume potential. Assuming that you are not bottle necking them back into the same size line.... as then you would be increasing the resistance, thus reducing flow.
Postby DMan1198 » Mon Dec 08, 2014 3:17 pm
You say you have 5, so To go with what Eric said you could 4 of them and run series parallel with the ip being dual fed
Postby dazedandconfused » Mon Dec 08, 2014 3:46 pm
Why not just dual feed the injection pump with one of those pumps running to each feed? That should supply more then enough fuel I would think for what your doing.
Postby ellis93 » Mon Dec 08, 2014 3:52 pm
dazedandconfused wrote:Why not just dual feed the injection pump with one of those pumps running to each feed? That should supply more then enough fuel I would think for what your doing.
True I could do that,but it would require a other fuel filter,another set of fittings and line. I already have about 100$ in just line and fittings. Plus I want to try and do this differently than what I've seen. It's a curiosity thing :D
Postby ellis93 » Mon Dec 08, 2014 3:55 pm
RCCUMMINS89 wrote:In series increases both pressure and volume....
The line Im using is 5/8 outer diameter and 1/2 inner,you don't think the flow would be enough in that size for two to work in parallel?
Yes Pete I did 8)
Postby PToombs » Mon Dec 08, 2014 6:06 pm
LOL Like I tell the kids, "Good Boy!" :lol: Whack 2 of them bitches on there in parallel and run it! 8)
Postby RCCUMMINS89 » Mon Dec 08, 2014 6:13 pm
Run it.
Postby ellis93 » Tue Dec 09, 2014 5:56 pm
It's the small details I miss.... :roll:
I only have one 1/2" pipe threaded bung in this fuel tank,it's also diamond plate,so making another around the bottom is a bad idea. I also have no access to a TIG machine either.
I'm assuming that would be a bad restriction in flow for both pumps to pull thru. :scratch:
Postby RCCUMMINS89 » Tue Dec 09, 2014 6:10 pm
Postby PToombs » Tue Dec 09, 2014 6:14 pm
Eric, that's friggin' awesome! And it's cheaper than the Sinister one I got! :shock: Now I'm pissed. :evil:
Not like I really need a dual feed, but if I had it............. :twisted:
Postby ellis93 » Tue Dec 09, 2014 7:00 pm
That's a nice piece,I'll keep it in mind.
Postby DMan1198 » Tue Dec 09, 2014 7:45 pm
Mine got shipped today. It'll go on jaeger when it gets a fuel system
Users browsing this forum: No registered users and 68 guests
