HE351\S471
HE351\S471
Postby DodgeFreak » Fri May 22, 2015 6:44 pm
Would a HE351 and an S471 with a T6 flange be a good compound set up?? (not sure on exhaust housing size other than it has a T6 flange) It came off a John Deere Tractor I believe. I have pictures of it some where on here. I'm trying to get a comp wheel for my off breed of a charger and then I have the s471 I've thought about making compounds out of it. Or would an HX35 be better?
Re: HE351\S471
Postby RCCUMMINS89 » Fri May 22, 2015 10:18 pm
Depending on exact specs of the 71.... excellent set up. 351/472 (471) with the 1.10 t6 and 83 wheel is great.
Re: HE351\S471
Postby oldestof11 » Sat May 23, 2015 4:50 am
Brad Ponci's daughter goes deep 12s with a setup near that size.
Re: HE351\S471
Postby DodgeFreak » Sat May 23, 2015 7:05 am
Looking back at old pictures it looks like the comp measured roughly 70.65 and the exhaust was 88.23.
Re: HE351\S471
Postby RCCUMMINS89 » Sat May 23, 2015 10:04 am
If the exducer on the exhaust is 88 ish...it's most likely the 96 wheel.
Re: HE351\S471
Postby DodgeFreak » Sat May 23, 2015 12:04 pm
I'm pretty sure I didn't measure it right back then. we are moving and the turbo is buried right at the moment so I won't be able to measure it for a month or so.
