New engine is back.
New engine is back.
Postby RCCUMMINS89 » Fri Jun 19, 2015 3:15 pm
The new engine was delivered today (finally). I've got to pull the old engine, and then transfer a few odds and ends, and customize a few things still. As the new engine has a 24 valve head on it.
Specs:
89 Block, blue printed and balanced. Stock bottom end components.
VP head, H.O. pistons (probably should of went a different route).
18.25:1 compression
Hamilton 182/214, Hamilton 103# springs, stock push rods.
7x.011 Micro blind VP injectors, honed 30% over at 3.7LPM.
62FMW (may switch to a 351/472 compounds prior to going in..... maybe).
Re: New engine is back.
Postby Remps » Fri Jun 19, 2015 4:05 pm
8)
Postby oldestof11 » Fri Jun 19, 2015 4:40 pm
Why a blue printed block? That is only a good thing on CU IN displacement restricted classes...
Sounds like fun though!!
Postby RCCUMMINS89 » Fri Jun 19, 2015 4:55 pm
Jon.......simply going off what the machinist told me. Why? Maybe that's what he is used to.... I didn't question it.
Postby oldestof11 » Fri Jun 19, 2015 6:58 pm
Just curious. Some times it is a marketing scheme and other times the builder wants it. I was just wondering the reason.
My grandfather raced circle track back in the 1960s-1980s. He built all of his engines and engines for his friends. Back then in "stock car" racing, when it was truly stock cars, blue printed engines were all the rage and for good reason.
Postby fatty » Fri Jun 19, 2015 9:03 pm
I vote for the compounds. It'd do sooo much better on the top end vs. the 62.
Postby RCCUMMINS89 » Fri Jun 19, 2015 9:24 pm
And theoretically on the low end. I agree 100%..... just not sure if the time frame will allow it prior to the engine going in. I've got a lot of things to do yet before it goes in. Plum in return line, plug holes, re do temp sensors, list goes on and on. Still need to get the correct heli coils for the lines.
Anyways, forgot to add..... compression came back around 18.25:1. Not as high as we originally were going for, but we didn't modify a thing (no recessed valves, or fly cuts). But I feel it should be a happy medium.
Postby DMan1198 » Sat Jun 20, 2015 12:22 am
Are you sure those are 110# valve springs? My Hamilton springs are 103's, and I've had them nearly a year.
Everything else sounds really cool though
Postby ellis93 » Sat Jun 20, 2015 3:06 pm
Eric these work well for adapting the lines.
http://m.ebay.com/itm/280789531390?_mwBanner=1
Postby RCCUMMINS89 » Sat Jun 20, 2015 4:21 pm
Are those a direct swap in? Proper length?
And yes Ducati, they are the 103#. Not sure why I had 110 in my mind. :roll:
Postby ellis93 » Sat Jun 20, 2015 4:25 pm
They will need to be trimmed a little but they work awesome. I loctited mine to the DV threads and they stay put.
Postby DMan1198 » Mon Jun 22, 2015 5:49 pm
110# used to be the standard, so it's understandable to have that in mind
Postby RCCUMMINS89 » Mon Jun 22, 2015 9:18 pm
Well, update.....haven't done a thing. Been too busy and crazy hot in the shop.
Postby DMan1198 » Mon Jun 22, 2015 9:31 pm
Story of my life. I haven't done a damn thing on my compound setup since I got my new job. Now there might be a hornets nest somewhere under the hood (not quite sure though. Dad got scared Wednesday by one, and left my hood open. Turns out both chargers are visible from ground level at quite a decent distance with the hood open, so more red is really going to be nice)
Postby VanillaGorilla » Tue Jun 23, 2015 5:53 pm
Why the 24v? From what I've read at higher rpm the 12v makes more power. I was considering doing a P7100 24v but it seems the don't mean Dick after 3k rpm
93 Reg cab LE 4x4 518AT, 145k and counting, pump turned up,Internal pump mods, Denny T stage 2, non IC DV's, timing bumped up, BD 40hp injectors,BHAF and me-built mandrel bent CAI,4" turbo back, Holley lift pump, new white with gold paint job, recieving more mods to tow the Duster and push this stupid WI snow.
VanillaGorilla
