Keeping IP alive w/stock lift pump
Re: Keeping IP alive w/stock lift pump
Postby RCCUMMINS89 » Tue Jun 07, 2016 10:09 pm
I'm telling you.........with a mechanical gauge leave air in the line......it won't bounce at all. With an electronic gauge, you have to use a needle valve. Snubbers suck from my experience and don't do snot.
Postby spencerdiesel » Sat Jun 11, 2016 8:47 am
I went to install the banjo, needle valve, gauge etc last night. Everything was going ok......then I lost one of the compression sleeves :| Not having another on hand, I was going to just close the needle valve all the way and see if it held.
I gave the piston pump a push or two (didn't even turn the motor over) and fuel started coming out of the outlet side of the needle valve....at a fast drip. I had the fuel line loosely attached at the needle valve (just hadn't bothered to remove it as i didn't think the needle valve would leak when closed), and the line securely fastened on the gauge side. Fuel dribbled out of the gauge side to........at literally atmospheric pressure.
I used the thread sealant per permatex, and snugged ( 4 or 5 ft lbs) all the fittings. Anyone have a gander as to what I did wrong?
The needle valve is one of the cheaper ones....
H1C/18
Fuel: THD 12 psi piston pump, THD fuel pin, 366 spring, fuel screw bottomed @ 3 turns, timing to the head/ >1/4”
Muffler delete
spencerdiesel
Postby spencerdiesel » Sat Jun 11, 2016 11:15 am
Any suggestions?
H1C/18
Muffler delete
spencerdiesel
Postby DMan1198 » Sat Jun 11, 2016 11:49 am
I would suggest not losing compression fittings. It won't seal at all without one regardless of how tight you go.
Postby spencerdiesel » Sat Jun 11, 2016 1:45 pm
Sorry I wasn't real clear. The needle valve was passing fuel even when it was fully closed. I only had the line sitting in the outlet of the needle valve because the needle valve was closed, so I didn't think any fuel would come from the valve outlet.
The low/no pressure dribble that made it out of the needle valve and into the line easily leaked out of the gauge-end fitting. The gauge side's compression ring was still intact and present.
H1C/18
Muffler delete
spencerdiesel
Postby DMan1198 » Sat Jun 11, 2016 5:51 pm
Admittedly I was teasing you. Is it possible that needle valve just doesn't ever fully close?
Postby spencerdiesel » Sat Jun 11, 2016 8:02 pm
Your good brah :D It very well could be, it was a $3 special....
So then, I'll be finding a good ole Napa valve
H1C/18
Muffler delete
spencerdiesel
