Timing thread
Re: Timing thread
Postby spencerdiesel » Fri Apr 01, 2016 7:19 pm
Thanks. What causes the extra case pressure that just bumping the pump 7 degrees doesn't?
Or is it relying on the higher case pressure to just advance static timing 7 degrees?
How long do most people run the KSB hot for? Just to race?
H1C/18
Muffler delete
spencerdiesel
Re: Timing thread
Postby PToombs » Sat Apr 02, 2016 11:56 am
Now you're asking for more info than I have, lol. I read it on here what happens with the KSB on so the info is here someplace, I just have no idea where.
I just kick mine on when I'm playing with it, I'm not sure what others do.
Re: Timing thread
Postby spencerdiesel » Sat Apr 02, 2016 7:08 pm
Is it rough on stuff to flip it in the middle of WOT? :D
H1C/18
Muffler delete
spencerdiesel
Re: Timing thread
Postby PToombs » Sun Apr 03, 2016 4:05 pm
Not sure. I have done it, lots of times.
Re: Timing thread
Postby spencerdiesel » Sun Apr 03, 2016 5:37 pm
How much timing do you have Pete?
H1C/18
Muffler delete
spencerdiesel
Re: Timing thread
Postby PToombs » Mon Apr 04, 2016 4:23 pm
IIRC it's set at 1.85mm. I had it up to 2.25 but it was rattling pretty good. Factory setting is 1.25. I don't what that comes out to in degrees, I have never seen a conversion chart for a VE in all the years I've been playing with 5.9's.
Re: Timing thread
Postby ellis93 » Mon Apr 04, 2016 4:39 pm
Re: Timing thread
Postby PToombs » Tue Apr 05, 2016 3:54 pm
Ellis, did you actually try that calculator? 2.25mm = about .12 degrees! I don't think that's quite right. ;)
Re: Timing thread
Postby ellis93 » Tue Apr 05, 2016 5:30 pm
PToombs wrote:Ellis, did you actually try that calculator? 2.25mm = about .12 degrees! I don't think that's quite right. ;)
Thats why i Posted it..........To see if y'all seen the same. I thought it was bonkers myself.
Re: Timing thread
Postby spencerdiesel » Wed Apr 06, 2016 5:29 am
I didn't want to say anything. I have issues with talking before thinking :|
H1C/18
Muffler delete
spencerdiesel
Re: Timing thread
Postby spencerdiesel » Wed Apr 06, 2016 7:29 am
If one wanted to keep base static timing at or below 17*, and sweep to 27* with the spacer, how much power could be attained roughly? Basically, how much rwhp could be made with 17* static timing?
H1C/18
Muffler delete
spencerdiesel
Re: Timing thread
Postby PToombs » Wed Apr 06, 2016 4:48 pm
I think it's more of a geometry thing, not an engine timing app.
Re: Timing thread
Postby spencerdiesel » Mon Apr 18, 2016 8:35 am
Anyone know how much the dealer would advance the p pump trucks when a customer complained of "low power" back in the day? My instructor has a 215 horse p pump truck he bought new and took it in (long time ago) to get them to bump it ;)
H1C/18
Muffler delete
spencerdiesel
Re: Timing thread
Postby DMan1198 » Tue Apr 19, 2016 3:35 pm
With a 215 pump it'd be a good idea to make a stop in the front of the afc housing to prevent full rack travel. That way it doesn't back the timing down. Apparently that makes quite a difference with everything else the same.
Re: Timing thread
Postby spencerdiesel » Thu Apr 21, 2016 3:20 am
Thanks Dman. Is there a p pump thread can go brush up on?
H1C/18
Muffler delete
spencerdiesel
