Hot side restriction in higher HP numbers
Re: Hot side restriction in higher HP numbers
Postby spencerdiesel » Wed Sep 06, 2017 8:04 pm
Around the 400 whp realm, would the .70 AR on a 62 sxe have any drawbacks (pick a scenario) compared to the same turbo with a .83 AR?
RC did your 62 have lower egts up top with the tighter hot side because it boosted sooner?
H1C/18
Fuel: THD 12 psi piston pump, THD fuel pin, 366 spring, fuel screw bottomed @ 3 turns, timing to the head/ >1/4”
Muffler delete
spencerdiesel
Postby DMan1198 » Fri Sep 29, 2017 6:14 pm
With a ve, absolutely no drawbacks. The turbine flows a ton, and the gate is always there just in case. If you had the airflow mods that bc847 has the.8 is more logical, but at this point none of us have airflow like David.
Postby spencerdiesel » Sun Oct 08, 2017 7:20 pm
Thanks Dman. It's impressive what the sxe's are capable of
H1C/18
Muffler delete
spencerdiesel
Postby DMan1198 » Mon Oct 09, 2017 4:46 pm
They are some pretty awesome little chargers, especially for the price.
