upgrade turbo or replace?
Postby jmos4 » Sat Jan 30, 2016 9:45 am
Hi,
I've got a 89 non ic with a stock turbo, I have a 99 intercooler that I want to add. I am not that turbo savoy, but want to have a decent driver with maybe 300-350 hp. I have stock injectors and a few small pump mods, 3200 spring.
Can I upgrade this with a true 4" outlet and add a elbow or new housing to line up with the intercooler I have?
Or am I better off swapping the turbo with one from a newer truck, second or third generation and if so what's the best bang for the buck
Regards,
Jim
1992 Dodge 250 4 x 4
currently 360 TBI
NV4500, NP241
Dana 60's 4.10 gears
soon to be Cummins powered
1989 D250
Cummins NV4500 (Donor)
jmos4
Re: upgrade turbo or replace?
Postby AHineman » Sat Jan 30, 2016 11:29 am
Best bang for the buck would be a used he351 or an s300g imo.
Postby RCCUMMINS89 » Sat Jan 30, 2016 5:48 pm
HE351CW or S300G like stated. Depending on how you use the truck, a 62SXE would work well too, but a turbo of that flow isn't needed at 300-350hp. At 350hp and above they are pretty happy though.
Postby AHineman » Sat Jan 30, 2016 6:03 pm
What are the specs on that 62sxe?
Postby RCCUMMINS89 » Sat Jan 30, 2016 6:42 pm
62/68/and then whatever turbine housing.
The 62SXE is basically an upgraded fmw. It has the efr compressor wheel and flows 76#/min, with a broader map than the fmw. It also gains a lot from the upgraded compressor housing.
It also comes std. with Borg's 360 thrust (instead of the already upgraded 6 pad like the fmw had).
Same turbine wheel and housing option.
Best thing ........ it is even more affordable at$1385 compared to $1500 for a (our pricing) "fully optioned" turbo (gated housing, v band compressor, etc... )
Postby AHineman » Sat Jan 30, 2016 7:49 pm
That turbo sounds pretty sweet. If you need to give one away for long term testing, let me know. :lol:
Postby RCCUMMINS89 » Sat Jan 30, 2016 8:27 pm
I don't even get giveaway, testing stuff...... :lol:
Postby AHineman » Sun Jan 31, 2016 11:37 am
Got a map you could post?
Postby RCCUMMINS89 » Sun Jan 31, 2016 12:47 pm
If I can find it again.
Postby AHineman » Mon Feb 01, 2016 9:27 am
Postby RCCUMMINS89 » Mon Feb 01, 2016 10:57 am
Not the same page I found the map when I did, but correct turbo.
Postby Remps » Mon Feb 01, 2016 4:15 pm
Right turbo, wrong map. Most sites seem to have misprints of the maps on the sxe turbos.
Postby AHineman » Mon Feb 01, 2016 5:17 pm
I need to download the latest bw catalog, they're usually in there. Either way, sounds very promising. I like the twins on my 2wd truck, but wouldn't mind something simple and cheaper on my 4wd. Sounds like it would work well with my stock non-intercooled injectors and leave lots of room to grow. Glad you mentioned it.
Postby PToombs » Mon Feb 01, 2016 5:25 pm
Maybe if anybody finds known good turbo maps they should start a thread for just turbo maps, and make it a sticky. ;)
Postby DMan1198 » Mon Feb 01, 2016 6:12 pm
That map is the one for the 369sxe. That 62 looks like it'd make a great secondary on The Roo Hunter while it still has a ve. I still want to try a gtx3582r as a secondary on brownie though
